If I buy a salvaged f150 and swap....
Old Dec 26, 2010 | 11:50 PM
06bluemeaniexl's Avatar
Originally Posted by shocker11
yeah considering out model and year trucks are only going for 7k-12k at auction right now
if you can spend 7 - 12K on a wrecker, why not trade in for a similar year / mileage 4x4? how upside down are you, or is your truck paid off? If its paid off, you should be able to get between 8 and 12 for a regular cab 2WD with less than 100K miles. If its a extended cab, a bit more.
if your truck is paid off and you got 8K, and have 12K to spend, you can easily get a 4x4 extended cab. if you want a regular cab, it'd be even less.
Old Dec 27, 2010 | 03:45 PM
Huitt24's Avatar
If you do your homework and figure out how much time is involved then double it and you still think you want to do it then go for it. I have cut 2 el caminos in half and made one so nothing is impossible. Of course this was done when I was much younger and had plenty of time and something else to drive.
Sometimes it is cheaper to buy a different truck and sell yours, other thing is that if you do this it has a sense of accomplishment that "hey I did this". Look at doing it in stages, Install the front axle, then instal the t-case, then work out the wiring. A lot of people will tell you it is a waste of time, but if it is something YOU want to do then do it.
Old Dec 27, 2010 | 07:18 PM
dilloncawthon's Avatar
another suggestion is to solid axle the front end to be cheaper. you will still need the tranny, x-fer case, and probably a few other things but you can get a dana 44 for a few hundred bucks. it will probably be cheaper and easier to set up than the ifs front end.
