Carrier bearing going bad?
Old Dec 10, 2010 | 09:26 AM
572379's Avatar
2004 150 4.6 8 ft bed. Whiring sound started a couple weeks ago, jacked it up and tracked it to the carrier bearing in the middle of the drive shaft-wondering if its a pain to change, never messed with one before. Tried searching but couldn't find much on the subject
Old Dec 10, 2010 | 12:26 PM
mdhawkin's Avatar
If I remember correctly you can get it as a whole assembly and it bolts directly to the cross member. Someone please correct me if I am wrong.
Old Dec 10, 2010 | 01:54 PM
tbear853's Avatar
Not long ago someone had one go bad, seems they were maybe going to have to get whole new shaft? https://www.f150online.com/forums/20...through-2.html
My old '77 it's easy to change and my '07 is a Scab with a one piece rear shaft with replaceable U-joints. I think it was '04 and some '05s that had the "other" not so easily serviced U=-joints though there are kits out with cutters that remove the staking and adds clips.
Here's a link from that other tread on a whole new shaft with standard U-joints and bearings for future serviice. http://www.driveshaftspecialist.com/Truckhtml/Ford.html
U-Joints with grease fittings ..... HAVE to be greased regularly.
Old Dec 13, 2010 | 09:37 PM
572379's Avatar
I have the 2 piece shaft-it does bolt to the frame as described-going to the dealer tomorrow to find out what has to be replaced-I have the service manual and it doesnt describe it at all
Old Dec 16, 2010 | 04:45 PM
572379's Avatar
According to ford its not serviceable-new drive shaft. Parts guy recommended a drive shaft repair facility that could press a new one in
Old Dec 16, 2010 | 04:46 PM
572379's Avatar
Next question-anyone know a trick for this or am I out 700-1500 bucks for a new shaft
Old Dec 16, 2010 | 05:51 PM
Find a driveshaft shop and talk to them.
Old Dec 16, 2010 | 06:46 PM
tbear853's Avatar
Did you look here at that link posted? Cheaper and Serviceable?
They do it mail order, even can have it made with 1 ton size U-Joints?
Old Dec 16, 2010 | 07:29 PM
572379's Avatar
I did check it out, thanks-it will probably be a solution if no shop around here can do anything with it, to be honest I might leave it awhile and see what happens
Old Dec 16, 2010 | 07:48 PM
tbear853's Avatar
Sure thing, but it ain't gonna get better.
Might be worth looking at salvage yards for a good shaft / bearing out of a later 07 or newer one?
Good Luck!
Old Dec 16, 2010 | 10:51 PM
572379's Avatar
I know a boneyard near me that has an 05 that I could get, but I think I might be better off with the aftermarket kit
Old Dec 17, 2010 | 04:37 AM
mhockey9090's Avatar
Thats the same link i posted for someone else to use. Good to know its getting around now
Old Dec 17, 2010 | 05:44 AM
MUD DIGGER's Avatar
are you talking about a front drive shaft or rear drive shaft...i just replaced my rear drivshaft in the spring of this year cause i couldnt replace my U-joints i also got my drive shaft custom made longer for my lift.....600 bucks is all it costed me
Old Dec 17, 2010 | 04:37 PM
572379's Avatar
The bearing in the center actually-need to replace the whole shaft according to everything I've heard
Old Dec 17, 2010 | 04:52 PM
572379's Avatar
talked to a shop claims he can replace it, not sure how if you ask me. If not a new shaft for 400, which seems very reasonable
