posi
Old Nov 19, 2010 | 11:27 AM
fx2mark's Avatar
posi
I'm Sure this is asked a lot of times. I have a 2008 fx2 truck 4.6, and i want to make it posi track. What are some options i can take? Thanks
Old Nov 19, 2010 | 11:32 AM
Veteran: Army
#1 welcome
#2 slow down and learn what options the truck currently has, start by posting your axle code
#3 hang out and enjoy yourself while learning
Old Nov 19, 2010 | 11:48 AM
Galaxy's Avatar
You only have one option...install a locking differential in your truck, period. Regardless of what axle you have, your truck does not have any type of posi rear end. You'll have to research some of the companies out there (Eaton, etc)to see if they make a diff for your rear end. If they do, great.
Old Nov 19, 2010 | 12:02 PM
Veteran: Army
he might have a limited slip
Old Nov 20, 2010 | 10:50 AM
Galaxy's Avatar
In a 2WD, 4.6? You're right, he might. Many people still don't consider LS a posi though.
Old Nov 20, 2010 | 12:18 PM
"Posi" is a generic term to describe a limited slip - GM calls theirs "Positraction", which is what made the term "Posi" popular. Ford calls theirs "Traction-Lok". They are both clutch-type units.
Old Nov 21, 2010 | 03:10 AM
FireboltJoel03's Avatar
Put a Detroit locker in it and never look back.
Old Nov 21, 2010 | 01:43 PM
ford norseman's Avatar
Eaton/Detroit True-Trac LS. I put one in mine and I love it.
Old Nov 21, 2010 | 08:24 PM
LateKnightRides's Avatar
Isnt posi where both tires spin at the same time and limited slip is where on turns it will change the difference in the velocity of the tires to help with turning? Like if one tire starts to slip it will give more power to the other one and take less power to the one slipping?
Old Nov 21, 2010 | 08:49 PM
2stroked's Avatar
Like GLC correctly said, they're both pretty much exactly the same thing - done with clutches in the differential. A locking differential (several types available) is the only thing that truly locks the wheels so they spin at exactly the same speed. (Unless of course you use a spool or weld things.) Lockers are great - in the right hands. Most folks wouldn't know how to use them. Limited Slip / Positraction units require no driver intervention.
Old Nov 22, 2010 | 12:19 PM
Again - "posi" is slang for GM Positraction, which is a clutch-operated limited slip, same as the Ford Traction-Lok.
Old Nov 23, 2010 | 08:29 PM
When building a truck ford calls it positraction..
