headlight lens question
Old Nov 8, 2010 | 10:18 PM
MTXThunder9500's Avatar
I happen to notice on my headlight lens this past weekend that it looks like it has tiny cracks in it have any of you had this happen? they appear to be on the inside of the lens itself I'm curious if you think it could be from the HID's being to hot maybe??
all the little dots on the lens are the tiny cracks i'm talking about.
Old Nov 8, 2010 | 11:00 PM
818F150's Avatar
probably the HID bulb heating it intensely and the plastic cooling quickly
Old Nov 9, 2010 | 06:01 PM
Dumb question I know but is there any way u think to prevent it?
Old Nov 9, 2010 | 08:00 PM
sam1947's Avatar
Are both lights the same ?? I don't think the HID bulbs are the culprit, the halogen bulbs get hot also. Possibly just a bad plastic lens that has deteriorated prematurely
Old Nov 9, 2010 | 08:03 PM
Actually they r both doing it I believe
Old Nov 9, 2010 | 08:07 PM
lx4life's Avatar
I noticed the same problem after taking my hid kit out, i only had them in for a week and it was not there before, I believe the hid is getting too hot in the housing I wonder if others with hids have this problem.
supercrewzn's Avatar
Id guess that it could also be from road debris hitting the lights. I have had HIDs in ebay projectors for 4 years and mine look nothing like this.
Old Nov 9, 2010 | 08:13 PM
Watson91's Avatar
I can't imagine the HID's heat output would be a problem. HID's require less watage then halogen bulbs meaning the should run cooler.
Old Nov 9, 2010 | 08:17 PM
I thought that at first bit after closer look the marks r on the inside
Old Nov 9, 2010 | 08:18 PM
You would think others would have this problem cuz I know im not the only one tha lives in a cold area where the lights would cool off fast
Old Nov 9, 2010 | 08:19 PM
I don't know what the temp difference is between halogen and HID. I would guess that a 35w HID wouldn't put out more heat than a 55w halogen.
That's what I thought too
Old Nov 9, 2010 | 08:20 PM
Here is a pic of my lights...
Old Nov 9, 2010 | 08:28 PM
I've been looking for a set that dosent look all ricey ever since I saw that it was ****in up my lens
Old Nov 9, 2010 | 10:20 PM
powerz69's Avatar
I've heard of this happening when baking the headlights with to much heat to take them apart. Were you running 35W or 55W? and for how long?
