My truck isnt proportional, need help what to do, photos attached. 2007 SCrew Reg Box
#32
Josh yes I 100% agree that the new ones look a bit more normal. Thanks for the complement. The rims are Eddie expedition rims. Previous owner switched them.
Did some photo shop and like the idea of 22's and street tires. Take a look.
This would be remove the lift front and rear and drop the back 2" using a drop shackle kit. I kinda like it. Positives is that I can actually park in parkades again and go through normal car washes. Plus gas mileage would be helped.
#33
My cousin used to have a red Chevy dually supercrew longbed that was lowered. He had 18 or 20" high polished Alcoas on it and that rig was so sweet...and LONG! It would turn heads! But you have a 4wd so if lowering is NOT an option then bigger rims and larger tires to fill out the wheel wells is about all you can do to make it look more proportional. OR lift it, put the '08 tow mirrors on it and make it look like a SuperDuty's slightly smaller brother. Stock height will just look meh....
#34
#36
I think you should leave it as is! I think the key with long trucks is the lift to make them look proportional so i think the setup you have is best. Lowering it any is just going ot make it look really long, for example, 2wds screws with the 6.5 look like trains. If it was mine i would leave your setup, take the running boards off, tint the windows, and put a weatherguard toolbox in it.
#37
#38
#39
Amen to not putting a roll bar on it!!*
Dude, your truck looks amazing the way it is! I have always thought the 6.5 beds look more tough! You have a great set up. I think if you went to 20's with less backspacing and 35" tires it would set it off quite nicely.
However, *It would require some trimming. I did that to mine. My tires kept ripping my fender flares off as I turned but you can trim the back of the flare just enough so it doesn't do that anymore. I also had to trim the plastic in my fender wells quite a bit. In my opinion it is well worth it for the look you achieve!
#41
I think the height looks great. I think you just need some wider wheels that have a lip on them. I think that flat face on the wheels is throwing it all off. If you have the funds put some more aggresive tires on it. I would look around the site and see if there are wheels you like and ask what size, offsets/backspacing they are. Good looking truck though.
