35's vs 37's
Old Aug 7, 2010 | 02:43 PM
flys-f150's Avatar
35's vs 37's
i have an 04 screw. i have a fabtech 6" ready to install a new set of 20x9's and two slightly used 35-12.5 toyo mts un-mounted..my plan as i gain 'milk money' for this. was to buy two new toyos and run them up front. they cost 9hun for a pair new locally..i have a chance to buy a set of 37-12.5 20 toyo mts 'slightly used..they look new, from a guy i know who traded his truck in for $12 hun..what would you do? pros and cons of 35-37. i do have a level kit up front now, but planned to remove it when i put in the fab-tech..
Old Aug 7, 2010 | 03:23 PM
05BlackFX4's Avatar
if you switch to 37's you will need to regear...your gas mileage will suffer as well.
I think the 35's look great with a 6" lift. You can still run a level kit with the 6" fabtech.
Old Aug 7, 2010 | 05:19 PM
IORf150's Avatar
I say get the 37's. Eventually your gonna do it since your already thinking about it. That would be dumb buying 2 brand new ones when you can get a set full set of 37's for a couple hundred dollars more.
Old Aug 7, 2010 | 05:23 PM
IORf150's Avatar
Just keep the leveling kit on when you put the fabtech lift on then just buy you a 2" aal. I think you would be very happy with the end result. That's my opion
Old Aug 7, 2010 | 05:24 PM
GTRider245's Avatar
Spending thousands of dollars to lift the truck and run the same size tires you can run with a 70 dollar leveling kit is stupid. Get the 37s and save your money to regear.
Old Aug 7, 2010 | 05:31 PM
IORf150's Avatar
You don't have to regear right away. Plus you could always just regear the rear. Just make sure you don't put it in 4 wheel drive
Old Aug 7, 2010 | 09:58 PM
flys-f150's Avatar
i still can't believe anyone can run 35's on a leveling kit..i have the ready lift and tried to fit 325-65-18's and they rubbed..had to drop down to the 60's
Old Aug 7, 2010 | 10:41 PM
GTRider245's Avatar
I don't know what is so hard to believe. Hundreds of people have done it with success. Were you using the stock wheels?
Old Aug 7, 2010 | 10:52 PM
mSaLL150's Avatar
Sounds like your a little strapped for extra cash, so Id do 35s since regearing seems way down the road. 37s without regearing is only going to cause horrible mileage and lots of strain on the transmission/overdrive.
Old Aug 7, 2010 | 11:27 PM
412Scott's Avatar
I have 37's on my truck and I have 3.55 gears.I don't have any problems.I will go with 4.56 next year.This is on my 2010 Dodge though.
As long as you have a set of gears from 3.55 up you should be fine is all I am saying for now.
Old Aug 8, 2010 | 12:03 PM
Drick's Avatar
Because IMO 35's look out of place on a leveled truck. They look to big and they rub on full steering lock if you have MT's
A 4 inch lift is perfect for 35's IMO. But if your going 6 inch I would deffinitly go 37's because 35's look real to small IMO on 6 inch lift
Old Aug 8, 2010 | 12:06 PM
Drick's Avatar
Not here. His shift points would be all weird and he would burn out his tranny with 3.55 gears. 3.73's would be a tad better but with the extra weight of the lift kit combined with the bigger tires you NEED to re gear to help the truck even move out of its own way.
Old Aug 8, 2010 | 01:42 PM
xxdriverxx's Avatar
Def do 37's, I have the previously mentioned $70 level with 35's.. and if your running a 6" you might as well go big.
Old Aug 8, 2010 | 05:25 PM
412Scott's Avatar
Damn ok.I guess the Hemi is a little different?Because my truck still runs fast as hell.My shift points are the same.I just don't want to mess up my tranny either.Thats the only reason why I want 4.56 gears.
What size gears are on your truck flys-f150?
Old Aug 8, 2010 | 07:18 PM
GTRider245's Avatar
Everyone has an opinion. You are entitled to yours, but you have to know that it isnt the same one most people with these trucks share.
And on a previously mentioned note, if you are so short cashed that you are considering buying two tires instead of four, you may want to consider wether or not you need to be lifting your truck in the first place.
