Universal Joints
Universal Joints
I am almost positive in thinking that the squeaking coming from my truck is the u joints... My drive shaft however, does not have clips like the older ones did, and appears to have the caps pressed in. Has any one put u joints in their 2004 and newer f150, and if so how did you do it?
The 04 is another wonderful design - the approved method is to replace the driveshaft. I believe there are kits made to convert them to a clip system, but they aren't cheap. You may want to contact a driveshaft shop.
Correct.
I was also convinced that I had a driveshaft squeak in my 2004 supercrew. I took it to the dealer yesterday, they said the rear end has to be repaired. I have 106k and the Ford ESP Base plan good until 135k. The service rep said its all covered under the plan and it covers a rental too. Its at a Lincoln Dealer.
About the driveshaft, ford does not sell the kit to replace the staked in u joints anymore, the only solution for u joints is to replace the entire drive shaft. You should look into local drive line shops to make one for you.
I think ford went back to standard clips somewhere around 2006.
try asking someone at tasca ford in rhode island
http://www.tascaparts.com/partlocato...?siteid=213668
If the '07 clipped shaft uses the same sized u-joints as yours, is the same length, and came out of a truck at least as heavily rated as yours, I don't see why not. If in doubt, talk to a driveline shop.
If it were me, I would rather replace the shaft with a custom made one or a chopped boneyard shaft (assuming I couldn't find a boneyard special to fit), even if it cost more, if only because it would gall me to pay Ford for another stupid throwaway shaft. Besides, with a custom (or equivalent boneyard) shaft, you could replace u-joints in the future without having to replace the shaft.
Back from the dealer. They changed the ring and pinion gears, side bearings and cups, pinion bearings and cups, axles bearings and seals, and limited slip clutches.
Squeak is gone.
$100 deductible.
Squeak is gone.
$100 deductible.
update, did some research and found that Advance Auto sells a kit for $93 dollars that comes with all the necessary parts to convert this style to a normal clip type (u joints, special cutter bit, shims, and clips). Ended up calling the local drive shaft shop, and the guy told me they convert them all the time and it would be pointless to make a new one when they could rebuild my old one for $200 out the door... Dropped it off this morning, so we will see. To add insult to injury, my passenger side window regulator crapped out on the way home to remove the drive shaft, found one at rockauto.com for $97 and it should be here thursday. The worst part is I'm left with driving my worthless 08 tundra work truck all the time, as if its not torture enough spending 10 hours a day in...
almost a thousand miles on the repair and the squeak has not returned.
