Transmission Temp Probe
Old Jun 1, 2010 | 10:53 AM
W.L.B's Avatar
Does anyone have any pictures and the required pieces needed to make it work? I have the bully dog watchdog and it doesnt have an option for tranny temp. BUT, you can just use one of the EGT inputs as the tranny temp. So I just need to figure out where to put it. I know you put it in the line directly before the cooler, but does anyone have any pics that can show me exactly what I need to do.
P.S. I searched but most of the threads contain with pictures contain pics to old albums and the links are broken.
Old Jun 1, 2010 | 10:45 PM
W.L.B's Avatar
Anyone?
Old Jun 2, 2010 | 10:14 AM
W.L.B's Avatar
Seriously? Noone has any idea on how to put a temperature probe in a 04-08 Automatic F150?
Old Jun 2, 2010 | 11:16 AM
City of Champs's Avatar
Can't be all that hard to figure out. Trace the cooler line find a good spot to to put a pipe or jic t. Or whatever in then take some pics for the rest of us. You could be that guy
Old Jun 2, 2010 | 11:20 AM
Here 5th hit on google
https://www.f150online.com/forums/tr...mp-sensor.html
Old Jun 2, 2010 | 11:23 AM
W.L.B's Avatar
Okay I have another question. What are the different types of actual probes. The system is designed to plug in a EGT probe. Are the connectors that connect to the gauge any different?
This is the one for the EGT, but im assuming that it will not work for the transmission temp.
http://www.bullydog.com/product/inde..._detail/303/10
Old Jun 2, 2010 | 11:30 AM
No that pyro isn't made for tranny temp. It's range is for exhaust temperatures hotter than what your transmission would ever run. I don't see why your bully dog doesn't have a tranny temp. There is alredy one on your truck. You can view it through your odometer or message centre even
Old Jun 2, 2010 | 11:50 AM
Well I just read your manual on bully dog's website. The feature of tranny temp is not listed which is bs. Try going throuh your list of guages again, checking for an update to see if they realized there lack of this feature or email them to ask what you should do. But for the price why wire it into your exhaust gas temperature?
Old Jun 2, 2010 | 12:29 PM
W.L.B's Avatar
Bullydog doesnt offer it as an option for some reason. Ive already called and asked. But I only paid 125 for the bully dog, lol, so its not that big of a deal. I breifly asked them if it was possible to monitor the tranny temp through the pryro gauge, and he said yes because they did it to a dodge ram that way. I just dont know what type of sensor I need to get that plugs into it. I know where it goes in the truck now, I just dont know what type of actual sensor to get.
Old Jun 2, 2010 | 01:38 PM
Just get a sensor that is 1/8" pipe thread that has a temperature rAnge similar to that of. Guage for tranny temp
Old Jun 2, 2010 | 01:46 PM
http://www.summitracing.com/parts/ATM-2258/
Old Jun 2, 2010 | 02:08 PM
W.L.B's Avatar
What would I connect that to my bully dog with though?
Old Jun 2, 2010 | 02:24 PM
W.L.B's Avatar
Okay I think I figured it out. I need to get one of These for the watchdog to be able to add a pyro gauge.
Now I just need to add a tranny probe instead of the EGT probe. It has to have the two wires. Red/yellow.
Old Jun 2, 2010 | 02:25 PM
You should read directions for how to install a sensor and guage
Old Jun 2, 2010 | 03:33 PM
W.L.B's Avatar
No I understand how. I just dont know what to type to look for a tranny gauge that would have those two wires coming off of it. Most tranny gauges only have a common ground and the wire that heads back to the gauges. BUT, I need something that has two wires coming from the tranny, back to that little box.
