EDGE programmer was cause my IWE problem
Old May 28, 2010 | 03:13 PM
weezie23mv's Avatar
hey guys! first post by the way, sorry its so long, but i think a pretty good one! after weeks of research and chasing lines and swapping out solenoids i finally have fixed my rattling and squelling i the front end!! after learning about the initial vaccum when the motor starts and check valves, yatta yatta, i realized my idle was just too low to produce enough vaccum to hold the truck in 2 wheel drive. i simply turned the idle up and tada! problem was solved. just another thing to check out if you guys are havin problems!
Old May 28, 2010 | 03:46 PM
mdhawkin's Avatar
Good info for first post - welcome to the site.
Old May 28, 2010 | 04:54 PM
mhockey9090's Avatar
Weird but glad you got it fixed. This should be good info for members that are having problems and also have an edge. Hopefully save them some money
Old May 28, 2010 | 05:47 PM
saleen's Avatar
How did you turn up the idle?
Old May 28, 2010 | 06:41 PM
It is one of the adjustments you can do with the Edge/Gryphon.
Old May 28, 2010 | 09:17 PM
Djacobs28056's Avatar
Sounds like the EDGE programmer was also the easy solution to the problem.
Old May 28, 2010 | 09:24 PM
Yep, sounds correct to me.
Old May 29, 2010 | 12:21 AM
weezie23mv's Avatar
yeah it was, i felt so stupid though! all that hair pullin and tryin figure out what was wrong, and it ended up being that simple. plus, the truck sounds much better now when idling!
Old May 29, 2010 | 09:19 AM
bdholsin's Avatar
What was your idle before and after you made the change on the Edge?
Old May 29, 2010 | 10:06 AM
gcart's Avatar
it should show 0. mine does. and then you just go up or down in increments of 5.
Old May 29, 2010 | 02:05 PM
weezie23mv's Avatar
it was idling around 600-650, i never messed with the idle because it only went up to 300. i thought to myself that that was way too low. i said well maybe, just maybe its adding 300, and sure enought it did..she purrs right around 950-975 now!
Old May 29, 2010 | 07:03 PM
FX4 Matt's Avatar
Registered User
950 idle seems a little high to me
Old May 29, 2010 | 07:21 PM
Edge recommends 700 to 1000. I set mine at about 800, then when I got the custom tunes, they are at 750 to 800.
Old May 31, 2010 | 12:10 AM
weezie23mv's Avatar
arite, thanks guys, might turn it down a hair, dont hurt to try!
