Window Problems
Old Mar 28, 2010 | 04:40 PM
W.L.B's Avatar
Window Problems
So I have the 530t window module that ties into my viper alarm that enables me to roll up and down my window via my alarm remote. Well yesterday something happened and my front windows wont roll down or up from the driver side. I took everything apart yesterday and managed to jump my driverside window to get it up. I just left the module in line. Well now today I started looking at it more and went to bestbuy and they said my module is probably crapped out since it is getting power, ground. Also if I use a circuit tester and push the down/up buttons I get power in the wires leaving the switch. But once it goes through the alarm box it doesnt come out the other side. They said just to run a jumper connecting the wires that you had to cut to install the window modulator back together again. Well the up part worked fine. When I went to do the down part it didnt work. And then the up part didnt work as well. Now my passenger side window wont roll down from the passenger side either. I can hear it trying to go up, but when I try to roll it down nothing happens. What the hell did I do?
Both switches are sending power out when I click them down. The back windows work fine. The passenger window used to work yesterday when controlled from the passenger side, but now it doesnt work at all either. The fuse on the window module is good.
Old Mar 28, 2010 | 05:53 PM
aggieforddriver's Avatar
that really sucks man
is best buy fixin it?
Old Mar 28, 2010 | 05:56 PM
W.L.B's Avatar
Im trying to get them to get me in so they can basically rip out the module and put my truck back to stock as far as the windows go. Then I can go ahead and determine if I need to get new switches, motors, or what ever the **** I need since I probably burnt something in my rush of trying to fix it. At least I am really good a removing my door panels for when my mirrors arrive.
Old Mar 28, 2010 | 06:56 PM
man that sucks big time.
but i guess that is good for door takin off experience lol
Old Mar 29, 2010 | 12:46 PM
W.L.B's Avatar
Anybody?
Old Mar 29, 2010 | 02:04 PM
dont know if this will be helpful but i found this
http://collegestation.craigslist.org...663767261.html
i guess if the problem is with the alarm you could replace it?
again, doubtful that will help but i thought id throw it out there
Old Mar 29, 2010 | 02:32 PM
W.L.B's Avatar
Thanks for that but the actual problem is a piece of the alarm. Not the entire thing. The window module is an add on.
Old Mar 30, 2010 | 01:46 PM
W.L.B's Avatar
Okay I went to the local audio/install shop and convinced them to let me borrow a alarm module. It did not work, BUT mine was bad (we tested it on one of their vehicles). THey wanted $140 for the box! I said screw that and went online, $45 shipped to my house, lol. So once I get that in I get to determine what my other problem is. I might have fried my switches in me trying to find a presidential solution for the problem. Garsh I love wiring.
