Whew! Spark plug change complete, no breakage...
Old Feb 26, 2010 | 03:03 PM
MGDfan's Avatar
Exclamation
Originally Posted by MHarvey
I just made sure to coat the seats and straps on the new plugs with the anti-sieze when I put them back in. ...
Hello! How ya doin?
Would you please elaborate on this part? The TSB says only on the extended shank, no where else, using hi-temp nickel antiseize.
What is the 'strap' and 'seat' you are referring to?
Otherwise, good job!
Thanks!
MGD v4.1
Old Feb 26, 2010 | 04:16 PM
^^^ Seat, where the plug seats in the spark plug hole, and strap, the electrode strap that straddles the center electrode.
Old Feb 26, 2010 | 04:35 PM
MGDfan's Avatar
Hoo boy - umm, okay , fer 2 points ... "what is a rhetorical question?"
I'm concerned that the OP put A/S on these points - in particular the strap. A no-no. "What is a misfire?"
MGD v4.1
Old Feb 26, 2010 | 04:43 PM
MGD. You should not ask rhetorical questions if you want serious answers. We don't need to confuse people here. This is not the place.
Old Feb 26, 2010 | 04:44 PM
MGD v4.1
That was the first thing I thought of. Maybe with the nickel, it is still firing.
Old Feb 26, 2010 | 04:57 PM
MGDfan's Avatar
Corollary statement:
Stealth. You should not respond to rhetorical questions if you know for a fact that was the intent. This is not the place.
Further - with all due respect, you have absolutely no authority to tell me - or anyone else - where, how or what to post. Clear?
OP - I was not going to let you hang here. I brought this up because no one else had/noticed. If it is as I suspect the implications can be serious.
MGD v4.1
Old Feb 26, 2010 | 05:10 PM
MGDfan's Avatar
Good stuff, dat nickel - should tell the HHO guys!
MGD v4.1
Old Feb 26, 2010 | 06:29 PM
MHarvey's Avatar
MGD, sorry, should have been seat and SHANK, not strap. Quick posting on my part let that one slip right through. I stopped about half way down the shank of the plug, so nickel anti-seize on the seat (tapered part) and then on down the shank, until about 1/4" from the actual strap area.
Also to answer the question for Mr. Extreme-- I couldn't tell you the actual part number on the plugs themselves, as I just went into the parts store and asked for the stock Motorcraft plugs for the 06 F150 with the 5.4. I tossed the boxes in the trash hopper and the trash ran today, so unfortunately I don't have access to the boxes anymore. On the carb cleaner, I just bought the STP brand carb cleaner, I've used it for tons of carb cleaning in the past and I usually keep a can around to clean up new rotors and such when I'm doing brake work on my truck or wife's SUV. On the anti-seize, I used the Permatex brand nickel antiseize, part #77124. It's a small bottle with a brush built into the top.
**Edit** Also forgot to add that unless the deep well socket you are using has the rubber donut in it to retrieve the spark plug, you will need a magnet to get the plug out, as they sit deep enough in the hole that you can't pull them out by hand. I used a regular mechanic's telescoping magnet to pull them out.
Old Feb 26, 2010 | 07:04 PM
MGDfan's Avatar
Excellent, sir!
Thanks again - and good luck!
MGD v4.1
Old Feb 27, 2010 | 03:21 AM
700hauler's Avatar
wow...sometimes amazes me the "holier than thou" attitude some of the people on this site have...
anyways, congrats on the successful plug change! I didnt have the ***** to do it myself as I was scared of plugs breaking and having to do all that crap in the parking lot of my apartment complex...And I bought the truck used and had 96,000 on it when I had them changed...luckily none broke and the dealership bill was minimal. I had the plugs replaced with the Brisk one piece plugs.
Also, for what its worth to those researching this topic. I believe using a quality gasoline in your truck greatly helps your chances of getting the plugs out with as little fuss as possible. My plugs actually looked pretty good after pulled and I run Chevron and Shell gasolines
