Maplight bulb replacement?
Old Feb 9, 2010 | 04:52 PM
motox852's Avatar
Guys, I have a 04 screw and my map light is out, how do I remove the lens to get to the bulb? Thanks!
Old Feb 9, 2010 | 04:59 PM
Carolinaboy32's Avatar
do you have the overhead rail system ? If so remove what ever container is on the rail and you can just pull down on the most front part of the map light plastic part and pull till it pops down. If it doesn't come down you're not pulling hard enough , seriously it takes a lot of muscle to pop it down. Same goes for the rear if you have the overhead rail system.
Old Feb 9, 2010 | 05:15 PM
mcline86's Avatar
what about if you dont have the rail system how, then how do you do it?
Old Feb 9, 2010 | 05:24 PM
W.L.B's Avatar
Id assume the same way, just without moving the trey out of the way first, lol.
Old Feb 9, 2010 | 05:28 PM
gcart's Avatar
Correct. pull from the rear.
Old Feb 9, 2010 | 05:29 PM
mcline86's Avatar
lol....good point
