How to- Interior LEDs
Old Nov 16, 2010 | 09:16 AM
  #121
pmason718's Avatar
Originally Posted by lsracer
Just thought I would let everyone know that I am probably going to redo my truck's LED's again a different color, third times the charm or so I hope. The reason I am letting everyone know is because this time I will have more knowledge and also would like to help everyone with taking more and better pictures and finally finishing this write-up, and hopefully making it a little easier to understand. So if anyone has any suggestions or requests as far as pictures or information feel free to tell me and I will make sure I answer everything this time around. I plan on starting over Thanksgiving weekend on the switches since I have an extra set and then doing the cluster sometime over my winter break. So please try to get the requests for what you want to see on the switches before then.
All I want to know is can I send these things to you and you do mind, lol
Old Dec 11, 2010 | 07:33 PM
  #122
FordMan7's Avatar
planning on doing this within a couple weeks, but gonna get help from the old man on this one i dont' know if i have the patience to do it alone lol
Old Dec 14, 2010 | 12:39 AM
  #123
Watson91's Avatar
I'm planning on doing my interior red soon. Can I basically count how many light points my switches have and decide how many lights I need from there? Your original list of what you need seems to be a little confusing and I'm not sure how many of each I need.
Old Jan 20, 2011 | 08:55 PM
  #124
Bryce Martinez's Avatar
Ok how many lights do i need for the cluster?????
Old Feb 1, 2011 | 04:34 PM
  #125
lsracer's Avatar
Are you building your own? Or are you just using the bulb spots already there? If your using the pre-existing spots it's 11 or 13 I don't remember which, sorry.
Old Feb 1, 2011 | 04:36 PM
  #126
lsracer's Avatar
Yep you can count the amount of white and red parts on switches and cluster and this will give you the right amount.
Old Jun 21, 2011 | 02:34 AM
  #127
MignDallas's Avatar
Originally Posted by fomoco466
here's a few pics of the stuff I've done do far.
Hey I wanted to ask how did you manage to get the red on the lcd on the climate control Ive already done mine but didnt see any leds behind it and i switched the ones I could to white leds but the lcd is still green any help will be appreciated. Thanks
Old Jun 24, 2011 | 03:20 PM
  #128
lsracer's Avatar
In order to change the color of any of the lcds, stock radio or climate control, the actual screen piece must be changed out with another piece of plastic. In order to achieve this you'll have to buy a piece of plastic the same color of your LEDs and shape it to the original piece and replace the original. It may look a little strange with white because if you look at the piece of plastic now it appears black; however, is actually green.
Old Jun 28, 2011 | 03:29 AM
  #129
fomoco466's Avatar
light change
that is what i did. I ordered a sheet of blue and red lexan. I put a bevel on it with my grinder to match the face contour, then I polish the edge with polishing compound and my dremel
Old Oct 26, 2012 | 04:42 PM
  #130
Sunsetter's Avatar
so how many and what kind of leds do i need to replace the headlight switch, the 5 cruise control buutons the hvac controls and the cluster? i have an 06 stx. so i dont have a tach in the cluster and the hvac is not the fancy climate control.
Old Jan 7, 2013 | 02:29 PM
  #131
FL0rida CrAcK3r's Avatar
Originally Posted by XPerties
#74, I used Matrix II 5 led from:
http://autolumination.com/74.htm
Take cluster out, take back cover off and remove light.
I'm wanting to take my cluster out. I know there are 11 factory bulbs on the back of the cluster, and these Matrix II bulbs you suggested will fit in the factory sockets. My question is, if I just take the cluster out and swap factory bulbs with these Matrix II bulbs, will I have any blind spots in my gauges?
Also, can I get to the factory bulbs without having to take off the needles? I sure wish this thread would pick back up. This mod, IMO, is the coolest mod I've seen yet.
Old Feb 22, 2013 | 11:13 PM
  #132
LydenWolfe's Avatar
HVAC leds
Does anyone have a diagram of the polarity of the LEDs in the HVAC control panel? I got all but the zone selector to work and cannot get any of them to work.
Old Jul 7, 2014 | 11:51 PM
  #133
twitch2788's Avatar
I really need to know what leds the dash needs..
Old Apr 5, 2015 | 07:35 PM
  #134
2008_XL's Avatar
Before I take apart my dash, can anyone confirm I have the correct bulbs for the cluster and odomiter?
Old Feb 23, 2016 | 02:48 PM
  #135
Levihendrickson's Avatar
I may tackle this job soon! Any advice before I awake the beast?
