What next?
What next?
Hi guys,
Got an issue that no one seems to be able to put their finder on.
I have a 2005 F150 Lariat 4x4 with a 5.4L 3v V8. The truck is running great at idle and under normal driving conditions. The issue is that between 4,000 and 5,000 RPMs I am experiencing either or both a cylinder 1 and/or 3 misfire (PO301 and PO303).
Here is a list of what I've done.
Timing chain
8 new plugs
8 new coils
New fuel injectors on 1 and 3
New PCM
Compression checked out at 150 psi
Had a muffler guy test the cats their good
What am I missing? Why would a truck only misfire at higher RPMs and run perfect any other time?
Cam sesors, crank sensor, EGR valve??? Anything? I got a code this morning that I have not pulled before PO351. Has to do with the primary circuit to Coil #1.
I would appreciate any and all feedback. Thank y'all in advance for your help.
Travis
Timing chain
8 new plugs
8 new coils
New PCM
Travis
