Panel Removal
Thats the one, it's in there pretty tight, any suggestions on were to pull from??
On the lower right side there is a L shaped catch the wraps around the metal support for the dash that connects to the floor. Then there is a spade catch that goes into the center console. If you pull on that left side then slide back a half inch it should come off.
