Which DieHard Platinum Battery?
Old Jan 8, 2010 | 10:52 PM
JJBravesFan's Avatar
I've narrowed my choice for a new battery down to the DieHard Platinum battery. Does anyone know which size battery I need?
My thinking is that the P-2 (Group Size 65) should work, but when I put my trucks details in, it says the battery is incompatible???? My truck is a 2004 (non-heritage) XLT regular cab w/5.4 engine. Any help would be greatly appreciated.
Thanks!
JJ
Old Jan 9, 2010 | 12:31 AM
Tylus's Avatar
just get the biggest one you can find.
there is a ton of room under the hood for one. I personally would grab a 850 CCA...or bigger
Old Jan 9, 2010 | 07:46 AM
Grubrunner's Avatar
Below is what I have...
DieHard P-2 Platinum Automotive Battery
Sears Item # 02850065000
Model # P-2
CCA - 930
RRP - $189.95
HERE
Old Jan 9, 2010 | 09:37 AM
Thanks guys. With the weather guys forecasting -24F last night and my stock battery probably getting to the end of its life, I figured I better be planning ahead for a trip to Sears.
Old Jan 9, 2010 | 07:35 PM
ScrewedUPF150's Avatar
930 thats a lot of cold cranking amps!!!!! I upgraded to the biggest motorcraft and it only has 750.
Old Jan 9, 2010 | 11:02 PM
tg150's Avatar
Ive got the P-2 in my truck. No issues or problems whats so ever..
What an incredible battery.. Great choice..
Old Jan 9, 2010 | 11:59 PM
silk05f150's Avatar
Yeah dude I just got the P2. Its a bad *** battery
Old Jan 10, 2010 | 08:31 AM
HCBPH's Avatar
Batteries
I haven't had a need to buy a battery in a couple of years, but when I have I've gotten the biggest one that will fit with the hightest cranking amps with the posts oriented correctly. The are different cranking apps in the same case and in cold weather, the more the better.
My 2 cents
Paul
Old Jan 10, 2010 | 06:05 PM
Grubrunner's Avatar
I went to storage to start my truck and drive it yesterday evening.
I hadn't driven it since October 20th 2009 when I put it in there. That's just a few days shy of exactly 12 weeks since storage.
I figured I'd take my portable battery starter with me... just in case. What happened?
Started first try with no signs of lag whatsoever... amazing! My Ultima RedTop would have, well and truly, died in the *** in the same time frame.... well before , actually.
Like silk05f150 said ... "this is a bad ***" battery!!
Old Jan 11, 2010 | 04:00 PM
Krohbar's Avatar
Not a bad idea.
And while you're at it, join the Nebraska thread...
https://www.f150online.com/forums/mi...-area-155.html
