stock horsepower question
Old Dec 21, 2009 | 06:13 PM
AOF150FX4's Avatar
I have been searching online for a baseline HP on my 2005 5.4L FX4 and just about all the websites I look at say my engine is a 330CI 3V 5.4L with stock 300hp, but I look on here and see people with a 5.4L with mods and they claim only between 240-280HP after running a Dyno. Am I missing something?
Old Dec 21, 2009 | 06:17 PM
kingfish51's Avatar
Yes. The stock HP ratings from Ford are at the flywheel. The dyno tests are at the rear wheel. The drive train causes a loss of HP.
Old Dec 21, 2009 | 06:18 PM
kozal01's Avatar
that engine is rated at 300 HP at the crank but after you factor in parasitic loss through the drivetrain measured on a chassis dyno you get the real rear wheel horsepower. 15-20% of HP is lost through the drivetrain
Old Dec 21, 2009 | 06:20 PM
AOF150FX4's Avatar
ive already done exhaust, intake, and gettin a programmer any other suggestions to get the power up there with out spending thousands
Old Dec 21, 2009 | 07:02 PM
PHS79's Avatar
There have been a few guys that had their stock trucks dynoed and most have seen 200-205 rwhp stock.
Besides the mods that you have already done, the best for hp would be: E-fans, underdrive pulleys, and custom tunes.
Old Dec 22, 2009 | 12:43 AM
AOF150FX4's Avatar
I've heard of underdrive pulley's, but what are E-fans exactly?
Old Dec 22, 2009 | 12:55 AM
Tylus's Avatar
you currently have a mechanical fan with a clutch
this sucks up a few HP from the belt having to turn the fan. e-fans = electric fans
most cars come with them from the factory. but trucks almost never do.
you can unbolt the stock fan, and then install an e-fan onto the radiator. besides freeing up some HP, the e-fans will cause less drag on the motor...which means it will rev up quicker
just throwing this out there, but you can still get the Roush Supercharger for $2,300. That will put you at 412 crank HP, 477 crank TQ...which equates to about 300 RWHP
Old Dec 22, 2009 | 01:36 AM
Just before you think of supercharging, realize these transmissions aren't made of platinum either, beef the engine up, beef the trans up, because its a good possibility of failure. Not the general modifications, but supercharging and using the supercharger to its full potential can kill these weak transmissions.
Old Dec 22, 2009 | 01:58 AM
dilloncawthon's Avatar
yeah the nonintercooled charger can come pretty cheap now days but i wouldn't say he would loose 112hp in the drive train
Old Dec 22, 2009 | 02:38 AM
Tylus's Avatar
I would
4x4 trucks lose more HP than a 4x2 truck via the t-case (roughly 15 HP)...and the drivetrain on a 04-08 F-150 sucks up HP without good tuning
custom tuning will place a N/I Roushcharger @ about 330 RWHP. the Roush tuning sucks...it leaves HP all over the table that any 1/2 decent tuner can recoup safely
FYI, there are many 400+ RWHP trucks on this site with the stock tranny and zero issues. I drove my FX4 like an idiot up to the day I sold her and the tranny was solid...not bad for a 6,000 lb truck that could powerslide pretty much on command. and mine only had the 412 crank HP roushcharger
edit:
weak transmissions.
sorry, but I have to disagree on this. these are hardly weak trannies. prior to buying my RoushCharger, the tranny was scaring the crap out of me. I finally called up Roush with a list of questions.
1 of the questions was specifically aimed at how strong the tranny is. The guys at Roush apparently did some drivetrain testing back in 2004/2005 and they rate the 04-08 F-150 drivetrain as capable of handling 500 WHEEL HP. That is anywhere from 550-600 crank HP. this is why Roush offers to replace the 3yr/36k warranty when you install their blowers on a new truck
Couple that with the # of guys who've been running blowers since 2004 with zero issues...and the way I drove the truck....I would say these trannies are pretty damn stout.
I know there has been a plethora of "broke tranny" stories recently, but then again, these trucks have been on the road for 5 years now. Also, Ford made millions of them. It's all about percentages. Sh*t happens guys. I'm sorry for those it happens to though
Old Dec 22, 2009 | 01:47 PM
LincolnMarkLT20's Avatar
Great info on getting HP, forgot to add exhuast. This will help lots of people who are new to this site.
Old Dec 22, 2009 | 05:00 PM
4.6 Punisher's Avatar
Compared to Mopar trannies, these are bullet proof.
Old Dec 23, 2009 | 04:02 AM
phattacorider's Avatar
Someone help me out. What exactly are underdrive pullies and how would they help increase power?
Old Dec 23, 2009 | 09:22 AM
mrolgren's Avatar
Take a look at this and see if it helps out.
https://www.f150online.com/forums/ot...e-pulleys.html
Also just search for "Underdrive Pulleys" and you get a bunch of threads on this topic as well as the e-fans.
Good Luck!!!
Old Dec 23, 2009 | 11:43 AM
Smok][n's Avatar
a stock non i/c roush setup should yield about 310-320 rwhp. i dyno'd at 308 when i only had the s/c, but my truck seems to be a bit slower than most.
I can attest to the weak transmission issue. I will admit that I am hard on the truck, but I'm currently at 85K miles and already had the tranny rebuilt once and then replaced after that... I seem to get around 35000 supercharged miles between transmission issues....
