stock horsepower question
Take a look at this and see if it helps out.
https://www.f150online.com/forums/ot...e-pulleys.html
Also just search for "Underdrive Pulleys" and you get a bunch of threads on this topic as well as the e-fans.
Good Luck!!!
Good Luck!!!
Goto this site and punch in your VIN# and it will tell you your hp among other things. I've seen several different ratings for 05's and newer 5.4 engines.
https://www.fleet.ford.com/maintenan...ls/default.asp
there is no other HP/TQ available in them.
the reason that site quotes different numbers is because of the Expedition. in 2005 Ford offered 2 different 5.4's for the Expy. The 2v and the 3v.
The Fleet Ford Website thinks that the F-150 is the same way.
all 5.4 3v's from 2004-2008 in the F-150 are rated at 300 bHP
I've just heard too many horror stories about trannys going out early and mine has a 1 - 2 second delay in reverse, and 1 second delay in drive so it has me a bit worried I may be a victum soon.
Oh definitely i'm well aware of that.
I would
4x4 trucks lose more HP than a 4x2 truck via the t-case (roughly 15 HP)...and the drivetrain on a 04-08 F-150 sucks up HP without good tuning
custom tuning will place a N/I Roushcharger @ about 330 RWHP. the Roush tuning sucks...it leaves HP all over the table that any 1/2 decent tuner can recoup safely
FYI, there are many 400+ RWHP trucks on this site with the stock tranny and zero issues. I drove my FX4 like an idiot up to the day I sold her and the tranny was solid...not bad for a 6,000 lb truck that could powerslide pretty much on command. and mine only had the 412 crank HP roushcharger
edit:
sorry, but I have to disagree on this. these are hardly weak trannies. prior to buying my RoushCharger, the tranny was scaring the crap out of me. I finally called up Roush with a list of questions.
1 of the questions was specifically aimed at how strong the tranny is. The guys at Roush apparently did some drivetrain testing back in 2004/2005 and they rate the 04-08 F-150 drivetrain as capable of handling 500 WHEEL HP. That is anywhere from 550-600 crank HP. this is why Roush offers to replace the 3yr/36k warranty when you install their blowers on a new truck
Couple that with the # of guys who've been running blowers since 2004 with zero issues...and the way I drove the truck....I would say these trannies are pretty damn stout.
I know there has been a plethora of "broke tranny" stories recently, but then again, these trucks have been on the road for 5 years now. Also, Ford made millions of them. It's all about percentages. Sh*t happens guys. I'm sorry for those it happens to though
edit:
Just before you think of supercharging, realize these transmissions aren't made of platinum either, beef the engine up, beef the trans up, because its a good possibility of failure. Not the general modifications, but supercharging and using the supercharger to its full potential can kill these weak transmissions.
If you beat the **** out of your truck you will fu*k it up. I have almost 90K and I have not had one trans problem. and there is plenty of guys that have supercharged trucks with no trans problems
Alright then, like I have said in my previous post, I have read alot of bad stories about the trannys failing so I thought it would contribute advice.
