drop shackles.....
Old Dec 17, 2009 | 10:29 PM
CcHARLEYcC's Avatar
drop shackles.....
anybody currently have the rear drop shackles to level the height? I just opened a business so can't spend close to a grand for a full drop kit.....i'm just trying to lower the A$* of my harley until I'm in a position to get a full kit. Any comments on these shackles will be greatly appreciated...i'm just concerned because they're relatively cheap and seem like a 30min install
Old Dec 18, 2009 | 06:37 AM
Windsor's Avatar
There are several companies that make drop shackles for our trucks. I just put a set of Rough Country drop shackles on mine. Price was good and they shipped the same day. Install might not be quite that easy if you have a vibration weight setup on the driver's side. I had to unbolt the spring from the axle to get the upper bolt swapped out, but was not a difficult job at all. Here's a link to the Rough Country shackles.
Old Dec 18, 2009 | 09:48 AM
CcHARLEYcC's Avatar
thanks for the info.....any change in ride quality? Did you go with a 2" level.....would love to see a pic if you have one. I like to see things installed on real trucks and not "Photoshopped" ones
Old Dec 18, 2009 | 10:11 AM
Windsor's Avatar
I haven't noticed any change in ride quality. I'm not sure why you would. My front is lifted 1", so I only dropped the rear 1". It's a 4x4, so I doubt a pic will help you much. It's dirty, but I'll try and get a phone pic up today. Otherwise it would be next week. I'm heading out this afternoon for an extended weekend hunt.
Old Dec 18, 2009 | 10:22 AM
05RedFX4's Avatar
CcHARLEY, is your truck 2wd or AWD? The awd versions have a lift block in the back just like the 4x4's do, all you have to do is take the block out, 15 minute job and a lot easier than changing shackles, been there done that so I know.
Old Dec 18, 2009 | 10:25 AM
CcHARLEYcC's Avatar
no i have the 2wd saleen charged model....thought it was funny they actually made the harley truck a 4x4. It looks like more of a luxury truck. I will say this, for some reason it looks like my rear sits alot higher than usual.. I'm gonna wash and wax this weekend so I should have pics up.
Old Dec 18, 2009 | 10:41 AM
05RedFX4's Avatar
Well since you have a 2wd, drop shackles are the best option. I have a set of DJM drop shackles I'm not using if your interested.
Old Dec 18, 2009 | 11:31 AM
Windsor's Avatar
That supercharger adds a lot of weight over the front end, so your front probably sits lower than a stock truck. I know I probably lost a 1/2" of ride height after I installed my supercharger.
Old Dec 18, 2009 | 06:39 PM
got37s's Avatar
Here is my 05 with drop shackles. Rides nice going down the road. I do notice it bottoming it out when towing or heavy stuff in the bed.
Old Dec 18, 2009 | 07:05 PM
StealthF150's Avatar
I have the Ground Force drop shackle installed on my 08'.Its a 2WD and completely leveled. Been on about 6 months now with no problems. Cost me $98. Installed in about a hour.
Old Dec 18, 2009 | 11:11 PM
gcart's Avatar
Here is mine with djm lowering shackles (2"). no change in ride. no change in towing (other then the suspension obviously sits 2" lower causing the "sag" effect when towing heavy.)
recent
recent
when i first installed, with quad in back.
first bought truck. (W/O shackles)
Old Dec 19, 2009 | 12:37 AM
I have the Ground Force kit on my truck -- dropped the back to just about level. I highly recommend the Ground Force kit because it already comes with the shims that are required to maintain your pinion angle. Lots of pictures (including a before and after on the shackle drop) in my gallery.......
Old Dec 19, 2009 | 10:16 AM
CcHARLEYcC's Avatar
thanks for all the input guys.....think it's the route im going to go for the time being. $80-$90 now and then maybe $600 down the line for a full 2/4
Old Dec 19, 2009 | 10:26 AM
I have had the Ground Force shackles for about 4 years and they are great. More pics in my albums.
Old Dec 19, 2009 | 11:17 AM
I had the GF shackles on for a while too. They are a good setup.
