Winter is back and so is the whistle
Last year it drove me nuts that I could not figure out what was whistling on my truck. Only happens in the winter when its cold. And only happens at certain RPM's-around 1800-2000rpms. Throttle partially down
Any ideas?
Any ideas?
There was another thread in this forum that had a few guys saying they've had issues with idler pulley's, belts, etc.. I have an issue with the Power Steering pump making an aweful whine/growl after its been sitting in sub-15 degree temps overnight, but it clears up within a few seconds.
Does it sound like a belt squeek, or a mechanical noise?
Mine just did it this a.m. after a soak all night at about 17 degrees. Sounds more like a kazoo to me. As annoying as it is it seems to be harmless. All three of my last F-150's have done it ('04 '06 and now my '08).
7 degrees here in NW Indiana and my power steering pump I swear is the culprit of a slight whine/whistle. The only reason I suspect this is because my steering fluid is no doubt thicker due to the cold and taxing the pump greatly. Turning the truck in either direction is more like having power assist than true power steering (used to have this on my '69 Mustang til I went w/ a rack and pinion setup and ditched the steering box and power steering pump assist). This is on an '07 FX4 Screw btw.
Its definitely not mechanical. Is literally sounds like someone is whistling under the hood. Almost like a vacuum leak. But only when its cold...
What is "activated" under load when its so cold out? Kinda like a choke on a carb motor.
I hadthe problem on my 08 the first winter. Seemed like clockwork it would make the tea-kettle whistle once it got down below freezing on a cold engine. I took it in under warranty, they changed the idler pulley out and the noise has been gone ever since.
Heres a video. Sorry for the bad quality it was with my Blackberry
http://www.youtube.com/watch?v=YPPslF0bV4I
