F150online Forums
F150online Forums (https://www.f150online.com/forums/)
-   2004 - 2008 F-150 (https://www.f150online.com/forums/2004-2008-f-150-80/)
-   -   Fitting 40's help (https://www.f150online.com/forums/2004-2008-f-150/397854-fitting-40s-help.html)
patshea098 Nov 26, 2009 05:41 PM
Fitting 40's help
Currently got a 8" Rize Lift with 38's. not big enough haha...ready for bigger.
Im looking at options other than a body lift which may be my only option
is there any shackle lifts i can put on with this rize kit or get some custom drop shackles for the rear end? Then im stuck with what i need to do to lift the front....probably only option are king coilovers.
anyone with any help?
dilloncawthon Nov 26, 2009 05:47 PM
yeah i've seen some lift shackles for our trucks but i don't remember where. supposed to lift like 2in.s or so. you could either run a leveling kit spacer or some new coilovers and crank them up to fit the 40's. there was a guy on here awhile back that had only a 9in lift, 6in. sus./3in. bl, and he had 40s with no rubbing. you just need to have the right backspacing and you should be able to run them with 10in.s of lift no problem.
06yz250f Nov 26, 2009 05:50 PM
ebay i think is where the shackles are at. PM chaz he has them on his truck.
as for the front, need to bump it to 10-10.5 inches and probly will have a little rubbing depending on your tire width and wheel backspacing.
eff one fitty was running 40s with 11" with some trimming. he was (6" lift + cranked coilovers) 8" suspension and 3 body.
IORf150 Nov 26, 2009 05:57 PM
Actually he was running 11" of lift, he started out saying he didnt rub, but I remember in a thread not to long ago he stated he rubbed. It wont let me post the link.
10-29-2009, 06:12 PM
Eff One Fifty
Vehicle: 2004 Ford F-150
i ran that setup for like 3 months, it rubbed. about the same as my 40's rub now. its a bit of a pain at times but nothing too bad. heres a shot
ROLLING ON 40's~~Airbags on there way!
dilloncawthon Nov 26, 2009 05:58 PM
here is the guy that was running 40's on just a 9in. lift. maybe ask him some stuff about his wheel specs so you can minimize the rubbing.
patshea098 Nov 26, 2009 06:06 PM
thanks guys for quick responses and great help.
i think im going to put some lift shackles on...im pretty sure theres 3" lift ones...and 2" ones.
The coilovers are where the money will be cause the shackles arent to expensive.
i cant remember the backspacing on my wheels but im running 20X10 KMC Monsters
06yz250f Nov 26, 2009 06:12 PM
a 20x10 might be pushing it for 10" of lift and 40's, im sure your wheels are at 4.5" backspacing. width will be the main factor of how bad you will rub. id look for a 13.5" wide just to limit rubbing.
i think you can still do a spacer instead of going coilovers, another option if fabtech still has blems, buy them crank them to 8" then add 2" or 2 1/2" spacer. their like $570 for both coilovers direct from them.
dilloncawthon Nov 26, 2009 06:15 PM
yeah i think the guy's wheel specs in that thread were 9.5" wide w/ 4.5"bs and a 13.5" wide tire.
patshea098 Nov 26, 2009 06:22 PM
the fabtech idea isnt bad at all
i dont want to run a spacer right now because the "spacer" that rize uses....dont want to use multiple spacers...seems dangerous.
I know king coilovers has a set for the rize lift, at 8" and can be cranked till 10"
do you think ill rub with my current 15.5" wide tires at 10 inches of lift? cause i got some life left in my tires still....so 10" lift with 38X15.50???
06yz250f Nov 26, 2009 06:36 PM
aviator runs 20" xd diesels? and 38/15.5/20 toyo mts i think? not sure rubbing issues and what not. there is also 9" lifted blue fx4 some girl drives it on the site with 38/15.50's on 18" MT classic locks. not sure of her name tho.
patshea098 Nov 26, 2009 07:18 PM
im tyring to find some lift shackles no luck yet, but also been in a rush....any help would be awesome
thanks guys!
im going to contact fabtech, fox, and king, to get prices on coilovers.
patshea098 Nov 29, 2009 02:28 PM
cant find any shackles.....anyone know?
adaniels88 Nov 29, 2009 07:04 PM
you could always make some yourself or go to a fabrication shop. Any place that can weld can make you some.
dilloncawthon Nov 29, 2009 08:45 PM
here are some 2in. ones http://app.infopia.com/Shop/Control/...d/0/rid/127794 looks like i might be using these when i go up another 2in.s.
patshea098 Nov 29, 2009 10:45 PM
thanks dillon!
anyone know if they are a reputable company?
also...should i use lift shackels or fabricate up some hangers, weld them to the frame?
