Hole in frame for exhaust?
Old Nov 21, 2009 | 05:20 PM
Allcarfan's Avatar
Originally Posted by gator68
Don't do it. You should'nt weld on the frame. The frame is forged and if you weld on it, you change the temper of the steel. By welding on the frame you are taking the chance of the frame cracking and breaking causing alot of damage. Also cutting a hole that is not suppose to be there changes the safety of the vehicle if you were involved in a crash. Thats just my .02 cents.
This is good info.
dribone...interesting....run under the frame and out the side...doesnt look like I could run longtubes though.
Old Nov 21, 2009 | 07:12 PM
Dribone's Avatar
tha frame isn't forged. it's stamped pieces of steel that are welded together. not to mention, crossmembers and brackets are welded to the frame, without the frame going through tempering after all that crap welded on. on top of all that, the frames on the newer 150s are 3/16" steel in a boxed formation. couldn't get any stronger on a light duty truck.
i'm still not condoning the hole in the frame, although i have cut more than my fair share of the frame... but the information provided needs to be correct.
Old Nov 21, 2009 | 10:27 PM
avfrog's Avatar
Originally Posted by arubba
Personally, I am NOT fond of the idea of cutting a hole in the frame. Since, it sounds like you have plans to go ahead with your plan, have you considered running a Round Sleeve/Cylinder through the frame slightly larger that the exhaust pipe and then welding the plates on either side? You could then pass the exhaust through the sleeve.......
I thought about that too. That is probably the best way to go, and it would actually be stronger after it is welded.
Old Nov 21, 2009 | 10:28 PM
avfrog's Avatar
