35'' mud grapplers on stock 18s
Old Oct 2, 2009 | 02:24 PM
clawdsupercrew's Avatar
i have an 04 supercrew 4x4 with a 2.5'' leveling kit. will i be able to fit a set of 35x12.50x18 mud grapplers on my stock 18'' lariat wheels without using wheel spacers? i know its going to rub at full lock, but what about with the wheels straight? are the tires going to hit the upper balljoints? i've seen some people run them and never mention anything about a spacer and then i've read on here that some say you'll have to have them.
if they rub with the wheels straight, how bad is it going to be? would it be ok just to let them rub and wear down the side tread til they clear?
Old Oct 2, 2009 | 04:31 PM
IDNC76's Avatar
here check out this thread..............
https://www.f150online.com/forums/wh...ctory-18s.html
Old Oct 2, 2009 | 05:18 PM
rngprerunner's Avatar
They will be just fine.
I'm running 35/13/18 Terra Grapplers on my stock FX4 wheels and they only rub at full lock. Ball joint clearance is fine.
Old Oct 2, 2009 | 06:15 PM
yetti96's Avatar
TGs are nothing on the sidewall compared to that of a MG.
Old Oct 2, 2009 | 07:41 PM
True, they don't have the claws on the sidewall. But they are 13" wide instead of 12.5. So I still say no problem.
Old Oct 2, 2009 | 10:13 PM
06' Ford's Avatar
So you have the 325/65/18?
