How does one fix a loose wire in the radio wiring harness?
If a speaker wire connection was loose inside the radio wiring harness causing occasional static sound, how does one go about fixing it? Can Ford do this without screwing something else up? Would an car audio place be better? It looks pretty clear that replacing the entire harness is not an option. Getting down in there with conventional tools, is not possible either.
Wire
Without see it, this is just general info. In a couple of previous vehicles I had to fix the connectors. On those there was a small tab that held the wire in the connector, took a special tool to slip over the male end and depress the tab, then you could pull the wire out of the connector. Clipped off that end, got a new one from an electronics store and crimped on a new one and pushed it back into the connector. Hardest part was figuring out how to get the first wire out of the connector, then it was a piece of cake.
Paul
Paul
