How tall do I need to go! LIFT
I need new tires and was wanting to go with 35's have 33's now. I have 2" leveling kit on truck now. The wheels have 5.5 back spaceing (KMC 20")
My Q is I want to go with the littlest amount of lift I can get away with.
I was thinking of 2.5 Leveling kit with Add a Leff. OR go with the 3" Skyjacker lift that most peple on here HATE.
Heres my truck now I have added Bushwacker Fender Flares
https://www.f150online.com/galleries....cfm?gnum=2538
Thanks for any help! AND sorry if this Q has been asked before!
to fit 35's you need i think 6.5" backspacing which are same as stock (someone correct me if its different).
only options would be suspension lift, with those wheels your only option is a rancho lift since they allow stock wheels, all other lifts i believe require around 4 1/2" backspacing on wheels.
or you could do a body lift if you didn't want to get suspension lift done.
Dont you have a 4.5" backspacing on your wheels . The last time i saw you had KMC Hoss, same wheel i have, and im pretty sure they dont have it in a 5.5BS. Anyway i think you need at least 6" to get 35" with those wheels you have. So i guess you could do the Rancho 4" with your spacer on top of that? I know i have a 3" leveling kit and there is no way i could get 35's without at least3 or 4 more inches without rubbing terrible.
I do have the KMC Hoss still. They may be 4.5 I thought they were 5.5 I have had the wheels for some time. I realy don't want to go with the Rancho because it will not fit in the garage.
Thanks Strikeswiftly
I may keep it the same and go with the TOYO AT 305/60/20 Tire
Nitto makes a 295/60/20. Ive seen on a new f150 on the showroom floor. They had to do some trimming, but nothing serious. I wouldnt think you would trouble fitting in the garage unless it is very very small. Most are 7 ft doors and you have to be pretty big to not fit in there.
Honestly Jason... If you seen the truck you cant telll... I wished i had some pictures of it because not many people are running a 295 wide tire. You are also talking half of an inch difference in tires, but you would be gaining an inch in height. Just an idea, i also think the TG's are better looking then the Toyos, but you know how opinions vary. Your truck looks good now they way it is, but i hear you on the lift.. IM there. You wouldnt happen to post some pics with the bushwackers on would you? I just bought some, but havent got them to paint yet. Eff one Fitty has a good idea!
Big_Smokey I'll try to get a pic of the truck with the bushwackers on.
I wish there was a pic of the truck with 295 next to the 305 tire. I may go down to tire shop and have them put both on and go from there...
or I could go with the 3" Skyjacker lift and 35's hehe
Thanks for all the info guys
