Fuel Gauge Stuck in One Position
I hope this the right place for this thread. Didn't seem to belong in drivetrain. I have an 04 SCREW that the fuel gauge has begun to stick at low levels (right around 1/4 tank). The miles remaining on the gas tank on the digital display is still counting down, while the gauge remains fixed in a position. I always assumed that the miles remaining somehow worked off the sending unit float position. So here is my question:
If the mile count down is still working, does that focus my trouble shooting on the gauge versus the sending unit?
Any ideas on how to check the gauge? It seems like the sending unit is the more common failure.
Fuel Gauge
Might not be the gauge. An easy one to do is see if there's a ground strap between the tank or sender to the frame or ground. Much older vehicle I helped a friend with many years back and that turned out to be his issue. Next would be wiring to insure there's no opens or shorts but beyond that you need someone more knowledgable than me.
Good luck
Paul
Good luck
Paul
^^^I was thinkin the same thing, I've done that once and it got stuck at the 3/4 line. Should be fixed after next fill up.
this ever get resolved for you? today i went to fill up (key not in ignition), and when i got back in, the gauge rose to just over 1/4 tank and sticks...
mine did the same thing two days ago....the key on thingy makes sense as it was cold and i kept resetting the guage by turning the key on while it was filling up seeing how much longer it was gonna take lol
Mine sticks at the 3/4 line if the key is on while i fill, but it used to stick around 1/4 if i would only add enough to get to 1/2 a tank or under. Now i make sure i fill it all the way up with the key off and it doesnt give any problems.
