Stubles on exceleration??????
Old Aug 23, 2009 | 05:14 PM
sampson01's Avatar
Not exactly punisher it could be a pending code also
Old Aug 23, 2009 | 05:23 PM
bnuts's Avatar
it seems to be tapering away like i cant get it to do it as often now like i could a day or 2 ago... could it just be bad gas???
Old Aug 23, 2009 | 05:27 PM
Originally Posted by 4.6 Punisher
If the CEL doesn't come on, then there will be no codes. You're going to have to catch it in the act.
You can throw codes with no CEL. Mine did that just that when my injector stuck open.
Old Aug 24, 2009 | 11:50 AM
bnuts's Avatar
nope i was wrong drove to work today on the interstate.... still stubbles.... wtf... it will be in the shop first thing in the monring...
Old Aug 24, 2009 | 12:15 PM
4.6 Punisher's Avatar
I hear so much conflicting information all the time regarding CEL's and codes. Thanks for the clarification.
Old Aug 24, 2009 | 12:40 PM
Mr. eXtreme's Avatar
Mine had done this I noticed it more when it was cold out. Stock tunes air intake tube and an exhaust are the only performance mods...
But when I jumped on it it would stumble / break up... But normal crusing and driving it was fine. After I replaced the fuel filter it got better. Haven't had a problem since but it hasen't been bellow 55' here yet.
Truck have a little over 54,000 on it now.
Old Aug 24, 2009 | 02:01 PM
Nicky Pass's Avatar
The same thing happened to me....I needed 3 plugs and COPs. It would be fine driving normal, but if you 3/4 to full throttled passed someone, it would break up and pop.
Old Aug 24, 2009 | 05:07 PM
jimmyv13's Avatar
^exactly my symptom. My stumble was bad with only one plug/COP, I couldn't imagine 3!!!
Old Jul 2, 2010 | 03:42 PM
artgarcia's Avatar
Originally Posted by jimmyv13
I had a P0171 code on my edge, so I pulled the edge out and took it to the dealer and told them the symptoms. The tech hook up a laptop and we went for a drive. He asked me to make the stumble occur, I did and he showed me the ignition on CYL 1 drop to zero exactly as the stumble happened. They changed the COP and the plug...been great ever since.
Wher is dealer's mechanic connect the laptop? To the OBDII port?
Old Jul 2, 2010 | 03:49 PM
jimmyv13's Avatar
Yes
