Question on Rear Diff 3.73 LS
Old Aug 20, 2009 | 10:09 PM
wcook's Avatar
Hello,
I have a 2007 F150 4x4 and have started to notice a slight vibration in the morning when I make a turn. I am thinking it could be the rear diff. After I make that initial turn in the morning the problem does not occur again. I had the diff fluid changed at 28,000 miles. I am now at 29,000. I am wondering if I should change the rear diff fluid again. I plan on driving this truck until it turns to dust so I want to be sure to take good care of it. Any suggestions?
I was just going to put in some friction modifier but I am afraid that they actually did put some in already and I would wind up with too much. Any help would be appreciated.
Thanks in advance,
Wayne
Old Aug 20, 2009 | 10:19 PM
05RedFX4's Avatar
Spend the money and get a real LS, the factory units are junk. Try to get one like the detroit truetrac, they do not have clutches so they don't need friction modifier.
Old Aug 20, 2009 | 10:31 PM
05RedFX4's Avatar
If you have the 5.4 engine, then you have the 9.75 axle.
http://www.drivetrainspecialists.com...duct-5441.html
If you have the 4.6, then your axle is an 8.8 with 31 splines.
http://www.drivetrainspecialists.com...duct-5411.html
Old Aug 20, 2009 | 11:09 PM
JGP2009's Avatar
im not fimiliar with that true trac whats the difference in the true trac and the locker? is the true trac a limited slip?
Old Aug 23, 2009 | 11:31 AM
Roadie's Avatar
Just add another bottle of friction modifier. Buy it from Ford.
Old Aug 23, 2009 | 08:40 PM
wcook's Avatar
Thanks Roadie. I bought some and added it. I will find out tomorrow morning if it worked.
05RedFX4 - I will be going your route if the FM doesn't do the trick.
It pisses me off that I am even having a problem . I baby this truck.
Thanks again for the help Gentlemen.
Wayne
Old Aug 23, 2009 | 09:41 PM
yetti96's Avatar
Warranty?
Old Aug 24, 2009 | 05:58 AM
risupercrewman's Avatar
While it's under warranty, let Ford correct it on their dime, if you go & install anything to that rear end, you will be screwed in terms of your warranty!!!
