Alarm install
Old Aug 7, 2009 | 01:37 PM
l337viton's Avatar
Alarm install
I recently bought a Viper 5901 2-way system from Amazon.com
Been reading the instruction manual that came with it and it seems to leave some information out (PATS bypass, etc.)
Is there other documentation (like an actual installation manual) that is available? I checked the website and didnt see anything more than what came with the unit.
I remember back in 2000 i installed a Directed (Viper i believe) remote start in my old Mazda pickup and someone on a Mazda forum was able to provide me with a vehicle specific installation manual from Directed. Any know where I could get my hands on this for the F-150?
Thanks!
Old Aug 7, 2009 | 02:28 PM
bigdog87's Avatar
Thanks!
http://www.the12volt.com/
l337viton's Avatar
Found this so far:
DIRECTWIRE™ WIRING INFORMATION - FORD / F SERIES LIGHT DUTY / 2006 / Remote Start
[PRINT THIS PAGE]
12volts lt. green/purple (20A) + ignition harness
Starter red/lt. blue + ignition harness
Second Starter N/A
Ignition dk. blue/lt. green + ignition harness
Second Ignition N/A
Third Ignition N/A
Accessory black/lt. green + ignition harness
Second Accessory N/A
Keysense black/pink + ignition harness
Power Lock pink/yellow - DKP or BCM, green plug, pin 9
Notes: The BCM (Body Control Module) is on the driver side rear cabin wall.
Power Unlock pink/lt. green - DKP or BCM, green plug, pin 1
Lock Motor pink/black 5wi DKP or BCM, blue plug, pin 2
Unlock Motor red/orange 5wi DKP or BCM, blue plug, pin 5
Parking Lights+ brown + switch or BCM, blue plug, pin 6
Parking Lights- N/A
Hazards same as turn signal wires
Turn Signal(L) lt grn/wht (F), lt grn/org (R) + turn signal switch
Turn Signal(R) wht/lt blu (F), org/lt blu (R) + turn signal switch
Reverse Light black/pink + DKP, gray plug, pin 13
Door Trigger black/yel (L), black/pink (R) - DKP, gray plug, pins 22, 23
Notes: The wiring above is for vehicles without keyless entry. Vehicles with keyless entry, the door trigger wires are found at the BCM, green plug. The LF door trigger is black/yellow in pin 4. The RF door trigger is black/pink in pin 5. The LR door trigger is black/lt. blue in pin 12. The RR door trigger is black/white in pin 13. Use all wires and diode isolate each.
Dome Supervision black/lt. blue + DKP, gray plug, pin 6
Trunk/Hatch Pin N/A
Hood Pin N/A
Trunk/Hatch Release N/A
Power Sliding Door N/A
Factory Alarm Arm N/A
Factory Alarm Disarm N/A
Disarm No Unlock N/A
Tachometer NOT red/lt. green or red ac any ignition coil or fuel injector
Wait to start N/A
Brake Wire lt. green + brake pedal switch
Parking Brake lt. green/red - parking brake switch
Horn Trigger dk. blue - switch or BCM, blue plug, pin 12
Memory Seat 1 brown/lt. green - memory seat switch on seat
Memory Seat 2 black/orange - memory seat switch on seat
Memory Seat 3 N/A -
Interface Module: Category:
Immobilizer Bypass Required:
Yes Type:
SecuriLock
Part #: 1100F
Alternate Part1 #: 1100X
Alternate Part2 #: 556SW
Alternate Part3 #: 556UW
Alternate Part4 #: DesignTech 20402
Alternate Part5 #: DesignTech 29402
Notes: Standard on all models. When using the 1100X, a software change to 1100FM is needed.
Smart Starter Kill Relays: Relay Type:
Starter Relay Location:
Underdash, Passenger side fusebox, #1
Part #: 6401A
Old Aug 7, 2009 | 02:46 PM
bigdog87's Avatar
That should be pretty much all you need.
Old Aug 7, 2009 | 03:23 PM
l337viton's Avatar
I think so too. I need to read up on the PKFORD manuals. Not 100% how they play together. Can you give me a brief summary on how they play together?
I think the PKFORD module plugs into the BCM, and then the Viper Brain plugs into the PKFORD module.
But like I said I need to read all the manuals now that everything got here
Old Aug 7, 2009 | 04:48 PM
l337viton's Avatar
Someone PM'd me about what parts I got. I'll post them up as a reference for others
Viper 5901 Responder Two-Way Security System $224.50 (Main Unit)
Directed Electronics 520T Back-Up Battery System $14.99
Install Essentials 513T Mini Piezo Siren $9.40
PKFM Ford Transponder Override -Upgradeable (revised XK04) (PKFM) $40.80
Directed Electronics 506T I.T. Audio Sensor $12.50
I was thinking of also getting the window control module... but I couldnt get myself to spend $50+ to be able to roll my windows up and down with the remote.
If I get the chance to do the install with time I'll try to get a write up and some pictures, but i promise nothing!
Old Aug 7, 2009 | 06:26 PM
bigdog87's Avatar
Was totally going to install just my remote start then I got it and saw all the wires, and was like forget it!
Old Aug 10, 2009 | 03:46 PM
l337viton's Avatar
Heh!
Well looking over the documents this past weekend I think I can do it... looks straight forward. Might give it a shot this weekend if i get the day off.
Old Aug 10, 2009 | 04:14 PM
TJ05FX4's Avatar
I installed my own remote start on my 2005 and ran into next to zero problems thanks to KC AutoSounds. Travis includes a detailed 10 or so page color document showing you what wires to tap into.
Every single wire you need is under the steering column or there under the driver kick panel and along the rocker panel. I was able to install my Code SRT-9000 alarm in about 2 hours and it has worked flawlessly from day 1. No problems whatsoever.
I've done hundreds of stereo installs, but never an alarm install until this one. Super easy!
Old Aug 10, 2009 | 05:17 PM
Gurt's Avatar
I wasnt even going to try to do mine. But I have 4 shock sensors, leveling sensors, 3 sirens, window modules, and proximity sensors (those were annoying so I turned them off, lol). If you feel confident great. But once you start there is no turning back. Make sure you solder the connections so they dont come loose. And dont cut ends to make it work. Do it right. This is part of my alarm harness...
Old Aug 10, 2009 | 05:30 PM
l337viton's Avatar
Do you have that document handy? Im sure if you scanned it and posted it up people would be very great full.
I've done a remote install in the past, was pretty straight forward, the alarm part has a little worried
Old Aug 10, 2009 | 11:09 PM
yetti96's Avatar
When I helped a buddy install my 5901 I was going to do a writeup but when involved with the install in the hot FL summer sun, I said forget it. Getting done was my major priority.
Old Aug 17, 2009 | 11:59 AM
l337viton's Avatar
So i gave it a shot on Saturday!
Got almost everything working, remote start was a bit problamatic. Note for anyone else ever trying this... The remote start module ships in "manual" mode it must be changed to "automatic" mode using the valet button (the manual describes this process). This had me scratching me head for about an hour checking all my wiring when the issue was just a programing step that I over looked.
Now my truck has progressive power locks. I know the Viper's remote should be able to unlock my doors when the alarm is disarmed. I just dont see in the manual how to wire this us. Does it one one of the auxiliary triggers along with a relay? If anyone has any experience with this I'd appreciate it!
Thanks!
