Is my truck a diesel?
Old Jun 24, 2009 | 07:05 PM
2004f1505.4x4's Avatar
Ok I know my truck isnt a diesel but today on my way to work I decided to lay into it pullin out onto the highway. I looked behind me to see my exhaust tip spittin black smoke out, not blue, not white,but black.
I drive the truck back and forth to work every day but dont really give it anything past half throttle. Could it be just some carbon build up or somthing.? I also sea foamed it about a week ago could it just be some left burnin out? Also the inside of my stainless tip is black like my dads Powestroke
Oh truck is a 04 f150 5.4 with straight pipe and rear cat delete and K&N intake. No tuner
Old Jun 24, 2009 | 07:12 PM
bjp207's Avatar
I'd say the straight pipe and intake without the tune may be causing some problems
Old Jun 24, 2009 | 07:15 PM
bigdog87's Avatar
agreed, mine does that too lol
Old Jun 24, 2009 | 08:14 PM
08FX4's Avatar
Especially the '04 model 5.4L with a CAI and no tune. You're most likely running very lean and that may be a contributing factor to your problems. I don't know about gas engines but I know on diesel engines black smoke is nothing but unburnt fuel.
Old Jun 24, 2009 | 08:17 PM
RileyDog's Avatar
Agreed. Was it black before the cat removal?
Old Jun 24, 2009 | 08:47 PM
I just noticed it today, the truck runs fine and the milage seems normal. Just kinda threw me off a bit
Old Jun 24, 2009 | 09:04 PM
RileyDog's Avatar
Get a tuner then. dyno tuned would be nice, but get the tunes, run the the datalog stuff and send it back in for a tweak.
Old Jun 25, 2009 | 12:16 PM
Tornadom's Avatar
I'm tuned, and have all of my cats in place... my tips are also black.
Old Jun 25, 2009 | 12:52 PM
squirtbottle09's Avatar
If your tips are black then you are most likly running rich. And no your truck is not a diesel.
Old Jun 25, 2009 | 09:24 PM
The rear cat delete and your lean condition are doing it. Also its also a little remainder from the sea foam clean out. My truck will blow a very very light amount of black smoke from a hard rev. I'm custom tuned with rear cats out.
Old Jun 25, 2009 | 10:29 PM
weazel's Avatar
Registered User
FYI, black smoke would be from being rich.
Old Jun 26, 2009 | 01:12 AM
thats what i've always thought. But I have no fuel mods. Only intake and exhaust. So In theory it should be lean.... I've been keepin an eye on it and the truck hasn't done it in awile.......and darren you have the gryphon right? How you like it?
Old Jun 26, 2009 | 01:17 AM
weazel's Avatar
Registered User
in theory yes, but some times mods will do reverse i put headers on once, i ran rich, suppose to lean you out..
Old Jun 26, 2009 | 02:02 AM
When I put my AEM intake on it made me run rich. It was over compensating for the air at low rpm's. A tune fixed it.
Old Jun 26, 2009 | 09:27 AM
that makes sence, whats a good tune to run?
