325's on stock 20's
I've got a 08 Screw FX4 with a 2 in level, and I'd like to see a picture of 325 tires on sthe stock rims... or 325's on 20" aftermarket rims with a level kit.
I'm wanting to see the look of 35's on the stock rims, before I go aftermarket. thanks in advance. |
in most cases 325's are gonna rub. i had to go to 285's on my 08 for no rubbing. after you have the front leveled it will go down a tad bit after it settles in.
going with a tire that wide on a stock rim is definatly going to cause the tire to wear alot faster in the middle then the sides and the mileage you get out of them will be about cut in half then if you ran a wider rim
Looking for the same and any experiences with them. I've seen a few trucks on the forums running BFG 325/60R20 tires on stock wheels recently, I'll post pics of theirs if they don't chime in. I've found a set for the right price but want to be sure they are going to fit without much issue on my 07 4X4. I figure I'll have to add a 2.5 level to make them work but I also have a Stillen front bumper that ideally I don't want to trim.
Pics of upper ball joint clearances, any necessary trimming, close spots while the wheels are turned, etc. would be great. I don't care about the rubbing at full lock, it can be avoided most of the time. |
35's on stock 20" wheels:
http://thejonesfarm.com/TruckWeb/Tru...es/lift_26.jpg http://thejonesfarm.com/TruckWeb/Tru...es/lift_27.jpg |
Originally Posted by VTHokieF150
(Post 3717397)
http://thejonesfarm.com/TruckWeb/Tru...es/lift_26.jpg http://thejonesfarm.com/TruckWeb/Tru...es/lift_27.jpg LOL VTHokieF150....I have the same Mickey's on mine, but in the 305/55/20 size. I personally think the 35's on a leveled truck look too tall....just me tho, but you have a 4" lift. NICE!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! http://i441.photobucket.com/albums/q...t/IMG_2041.jpg http://i441.photobucket.com/albums/q...t/IMG_1416.jpg |
LOL! Yeah, guess I was a little quick to post and too slow to think! He can just picture the truck 2 inches lower. I would prefer running the 305/55/20's with a leveling kit myself. They look great and you shouldn't have to worry about rubbing.
| All times are GMT -4. The time now is 12:31 PM. |
