Will expedition motor fit in f150?
Old May 5, 2009 | 08:49 AM
BtownFord's Avatar
My buddy's early 2004 f150 oil pump decided to crap out and caused the motor to become locked up. Long story short, 2 different mechanics both said a new motor is needed. We are exploring pretty much all possibilities and I was wondering if an expedition 5.4L 3 V would fit that did NOT have the 6 spd tranny.
I would think thats its the same motor with maybe some transmission adapters needed. What do you guys think about that?
Any other options?
Thanks in advance
Old May 5, 2009 | 08:59 AM
Carlsson3's Avatar
How about this one ;^)
http://www.fordracingparts.com/parts...KeyField=10261
Old May 5, 2009 | 10:17 AM
Quintin's Avatar
It should drop right in. From the firewall forward, the F150 and Expedition are mostly the same.
Old May 5, 2009 | 10:49 AM
BtownFord's Avatar
thanks quintin. I was guessing that it would, but just wanted to make sure. Do the expy use the same transmission?
Old May 5, 2009 | 11:11 AM
Quintin's Avatar
Yes, 4R75 just like the F150. The operating strategy may be a tad different in an Expedition, but that's mostly in the PCM which doesn't matter since you'd be using the F150's processor.
Old May 5, 2009 | 10:35 PM
redx's Avatar
The 2004 f150 does it have the 3v in it now?
Old May 5, 2009 | 11:58 PM
Tylus's Avatar
from comparing my 2006 F-150 5.4 3v, and my 2008 Expy 5.4 3v, they look identical
my 2008 has the new heads/plugs, but the overall motor is identical.
so basically, take the new motor you find, strip it down to just a bare longblock without any accessories or upper intake, and put the F-150 parts back onto it. Should be a 100% plug 'n play at that point
Old May 6, 2009 | 04:37 AM
code58's Avatar
They all came that way, unless it is the Heritage (old body).
Old May 6, 2009 | 05:25 AM
GreenBuck50's Avatar
He might have a 4.6 2V in the truck originally though. He never said which engine was in the truck unless I missed it.
Old May 6, 2009 | 03:21 PM
RoushF150's Avatar
Carlsson3,
Love that engine! I can pick one up for $15K. But, I noticed theres a $2K wiring kit on it. Once you start to hit $20K, it makes you think twice about it as these trucks aren't worth the hassle.
Old May 6, 2009 | 03:54 PM
Quintin's Avatar
Be advised though that some valvetrain parts are different between '04 and '05+, so if you ever have to order cams, followers, etc. for it, make sure you let the parts house know that you have a 2005 engine.
Old May 9, 2010 | 09:04 PM
khackr's Avatar
2008 expedition to 2004 f150 engine
I did the same thing and have not been able to make it run correctly, wont idle and
p0340 code. tested all wiring and sensors.
Did your changeover work?
