Airbag warning light
Old Apr 25, 2009 | 12:39 PM
hmustang's Avatar
Unhappy Airbag warning light
Well this morning I start the truck and head off after a minuted the airbag warning light in the dash started to blink. It done this for a minute or so then stayed on. I have't been in a wreck or hit anything with the front of the truck so I was surprised to have something go wrong with the airbag system. Truck has 47k on it any ideas why something would fail if it hasn't been in a wreck.
Old Apr 25, 2009 | 12:45 PM
Possibly a sensor is bad.
Old Apr 25, 2009 | 01:00 PM
Impact9's Avatar
Check the yellow plugs under the seats one of them may have been kicked loose. Be sure to disconnect the battery first then unplug and plug them back in. Is the light the one above the radio the one flashing? I know if that comes unplugged it illumates a light on the instrument cluster. I forget which though.
Old Apr 25, 2009 | 01:14 PM
Tylus's Avatar
been raining in your area alot lately?...if so, you driven through any big puddles?
I'd try Impact's suggestion, the go looking on the frame at the inertia sensors. Maybe gotten wet. I've had that problem before with the wifes old vehicle
Old Apr 25, 2009 | 07:50 PM
hmustang's Avatar
It the one in the insttrument cluster the flashes. I have a reg cab and the conections under the seat loked good.
Old Apr 25, 2009 | 08:16 PM
Tbird69's Avatar
You'll have to plug in a scan tool to check for codes, if the instrument light is on steady then it likely set one.
