too much fuel ...
Old Apr 23, 2009 | 06:43 PM
FordsForMe's Avatar
too much fuel ...
Twice now I have had my gas tank filled at a local station and when I pull away the guage measures lower than when I pulled in. The first time it happened I thought there was something wrong with the pump so I went back and had them try a different pump to see if the really put the fuel in. Clicked off right away. When I fill it up at other stations I don't see this issue with the guage. Is this common? Is the pump over filling my truck? When I leave the guage seems to sit below 1/4 even though its normally just above 1/4 when I fill it. Is this something I need to get checked out? Thoughts?
Old Apr 23, 2009 | 07:00 PM
NoLongerJeepin's Avatar
Do you leave your key in when you fuel up?
Old Apr 23, 2009 | 07:03 PM
lObOdiablO's Avatar
check u battery sometimes causes the dash going crazy
Old Apr 23, 2009 | 08:03 PM
06F150STX's Avatar
if you leave the key in the on position just to hear the radio as you fill up, it will stay the same, until you turn the key to off and then back to on again. then you will get the right reading on your gauge.
Old Apr 23, 2009 | 08:27 PM
bigdog87's Avatar
I don't trust my gas gauge I just fill up every 300 miles.
Old Apr 23, 2009 | 11:23 PM
FordsForMe's Avatar
key was in .. but not on .. I drove it 5km the first time before I even noticed it.
Old Apr 25, 2009 | 01:38 AM
squirtbottle09's Avatar
Ive noticed that if I fill up completly full from empty it takes a while for it to register. I dont know if it is so full that the guage cant register or what. But after about 10-15 mils it registers completly full. And during those 10-15 miles I can watch the guage move.
Old Apr 25, 2009 | 07:47 AM
NCSU_05_FX4's Avatar
It must be something with your Canadian gas...
- NCSU
Old Apr 25, 2009 | 09:22 AM
Tbird69's Avatar
- NCSU
Nothing wrong with our gas, it's pure and clean. Just like our air.
