Question about changing plugs ???
Old Apr 22, 2009 | 08:50 AM
Fish Chris's Avatar
BTW, I read as many pages of the broke vs. non-broke thread below, as I had time for.
Anyway, my truck only has about 6K miles on it.... but I was wondering if there is a "safe" amount of tourque one could apply to these plugs, and then, if they came out, "great" ! I could put some new plugs in (whether it needed them or not) using some of that anti-seize plug stuff {I forget what it's called, but my friend / mechanic never does a plug job without it} and then, I could have my mechanic change my plugs every 50K, or whatever.
Of course if they didn't come out with "the safe amount" of torque.... Houston, we have a problem.
I'm just thinking that maybe I can avoid a problem down the road, by removing my plugs early "before they are baked in" and doing some cheap, easy, preventative maintenance.
Your thoughts ?
Fish
PS, BTW yes, I do have an 08' 5.4L
Old Apr 22, 2009 | 09:01 AM
Do you have the black plug boots or the brown? If brown, you have the revised heads.
As far as changing them out now, do it if that makes you happy. I just don't think that way. I had mine changed at 65,500, the TSB was followed and all came out fine. If one had broken, we now know how to get them out. I went back with the Motorcraft and plan on going 80,000 to 90,000 on them. I also use a gas with a good detergent such as Shell , Texaco and Chevron. I believe that they usually come out if the TSB is followed explictly and there is no "iI'll do this because it's better or shouldn't make a difference".
Old Apr 22, 2009 | 10:32 AM
Tbird69's Avatar
Like Bluejay said if it makes you feel better then do it. I believe the fix came about late '07 which would have shown up on the '08 models. Check your build date, if it's the later part of the run you should be ok. It's possible some of the earlier built '08's could have gotten left over '07 engines that still had the old head design.
Old Apr 22, 2009 | 11:34 AM
FATHERFORD's Avatar
Pull them out, put on antiseize, call it a day.
Old Apr 22, 2009 | 11:37 AM
05_sprcrw's Avatar
The TSB says that you should encounter no more then 33 ft lbs of torque to pull the two piece plug.
Old Apr 22, 2009 | 12:01 PM
Tbird69's Avatar
Here's what I find strange, it takes 33 ft lbs to turn the plug OUT, and that resistence is there almost all the way out. The new plugs are tightened to 25 ft lbs. Somethings wrong there.
Old Apr 23, 2009 | 12:15 PM
Fish Chris's Avatar
Thanks guys.....
Hey Bluejay, I went out and checked, and my spark plug boots are "brown".... Thank God.
Tbird, no kidding, huh.... Hmmmm.
Peace,
Fish
Old Apr 23, 2009 | 12:16 PM
Peace,
Fish
You're a lucky guy!
Old Apr 23, 2009 | 12:17 PM
That's good. The brown boots match your truck.
