Keypad lighting
Old Apr 25, 2009 | 07:48 PM
  #31
ZeroDormancy's Avatar
Originally Posted by fomoco466
after I do a swap the the radio or the a/c I make a lens out of acrylic plate colored the same as the LEDs. check my pics
where do i get this acrylic plate you speak of??? im absolutely clueless as to what u mean...thanks in advance
AWESOME i made the right call, i ordered 50 red plcc-2's
Old Apr 25, 2009 | 09:06 PM
  #32
fomoco466's Avatar
check this out
check out this listing on Ebay. this is the same guy I use.
http://cgi.ebay.com/Blue-Plexiglass-...3A1%7C294%3A50
Old Apr 26, 2009 | 02:41 AM
  #33
BM150280's Avatar
I've been looking around a little on exactly how to go about changing the keypad colors, (sick of the green) and I found this on another site. Not sure if the new model f-150 keypad is anything like the one shown on here, but I thought I would post it anyway.
http://www.explorerforum.com/forums/...d.php?t=193400
Old Apr 26, 2009 | 09:07 AM
  #34
just ordered a sheet of red, thanks a lot man. how did you cut it?
Old Apr 26, 2009 | 01:32 PM
  #35
fomoco466's Avatar
lens color
I just used a razor knife, went over it several times. I used emery cloth set on something hard and then rubbed the lens aginst it to get the angle/bevel I wanted at the top (a/c panel lens)
If you get it scratched, then I used scratch out (pollishing compound) to get it out, just like clearing up yellowed headlights.
Use a good cement (superglue will leave a white residue) I used model car cement
my first lens I made from a chip clip, lol got tired of waiting for the sheet to get here, Good luck with your mod
Old Apr 29, 2009 | 07:40 PM
  #36
so i got my led's and stuff in the mail, tried to do a solder. it appears to be perfect yet its not working. any ideas? here is what i got
http://www.oznium.com/plcc-2
i got the red ones
i just dont know what it is that im doing wrong. and now 2 led's are inop...
Old May 1, 2009 | 12:10 AM
  #37
fomoco466's Avatar
LED's
Remember the LED's are polar, if they don't work flip them 180 and try again... if you look closely you can see a corner of the led is missing, that should match the direction of the ones you are removing...also there is green color on the led's to help with the direction...... get a 9v battery and wire it up so the panel comes on with the battery....remember the + and the - remove one OLD led and set the new one in it's place, move the new led over the soldier points till it lights, once lit soldier in place! I do that with all the stuff I swap, that way you know it'll be lit (good soldier job) and then you can go onto the next with out having to plug it in the truck to test it!
Old May 1, 2009 | 03:53 AM
  #38
hmm good idea, thanks
Old May 1, 2009 | 07:22 PM
  #39
success! i did the radio, hvac, steering wheel, and headlight switch LED's. it looks great so all i need to do now is the guage cluster, door switches, and sunroof/rear window switches. Ill be doing these on monday and will have pics then. This is really and easy job once you get going.
Old May 25, 2009 | 12:23 AM
  #40
sherrod624's Avatar
how did you do the rear door switches? witch side of the circuit board did you soider the led's??? I started with the rear because i thought they were the hardest. now since i cant figure them out i'm having second thoughts about doing the rest
Old May 25, 2009 | 12:32 AM
  #41
JERU's Avatar
Originally Posted by the4by4freek
A new user!!!!!! ARE YOU FREAKIN KIDDING ME? I got the answer I was looking for. Look at my join date! If I didn't contribute anything to this forum, I wouldn't have said anything. I have found fixes for the cowl issue, and successfully repaired them. Posted installs for I pod installs and many others. You are a new poster..... WHO ARE YOU TO TELL ME ANYTHING! Just because I don't have a million posts doesn't mean I haven't been here for a long time..... it just means I have other things to do. For your information, I might have an issue that no one else has come across yet! When I do get it repaired, I will, as always post the repair for it along with the procedure to do so, just like I have always done in the past! If you had been here before, you would have known that! Now, I have nothing more to say other than GO AWAY! I an not some snot nosed kid that me daddy gave everything to. I am most likely older than most others here. You need your A$$ kicked.
Thanks for the effort of posting your solutions, helps out a ton. Don't let a few people get you worked up
Old May 25, 2009 | 01:26 AM
  #42
zachespo's Avatar
If you have the switches apart you just unsolder the old leds and solder the new ones on. Making sure the polarity is correct.
Here is my thread about the light changes. However, i did mine a little different, i took the light boards out and just wired in 3mm leds with resistors which is a little more difficult but gives the same result.
Leds
Old May 25, 2009 | 10:02 AM
  #43
sherrod624's Avatar
[QUOTE=zachespo;3739012]If you have the switches apart you just unsolder the old leds and solder the new ones on.QUOTE]
I understand that, and most of them are just as you said, unsolder and resolder. My problem is with the rear windows, and the door locks(i think the locks are the same). the circutry is on the bottom side of the circuit board. so obviously i pulled the circuit board off, just as the fella did earlier in this post. but the led is sodered face down with the bulb sticking through the board. My plcc-2's wont fit through the hole and if i solder them on upside down then ive gotta fill a big gap with soder. Unless im just making this harder than it is, im a little lost on those 4 buttons
thanks for any guidance you can give
Old May 25, 2009 | 01:08 PM
  #44
fomoco466's Avatar
through hole LED
Here's what I used for my through hole LED's they work great.........not this person by the way... just that type LED.
http://cgi.ebay.com/50PCS-0603-Ultra...3A1%7C294%3A50
Old Jun 5, 2009 | 05:18 PM
  #45
sherrod624's Avatar
HOLY COW!!! i got some 0603's in today and MAN are thos things little. i sure hope they work
