rancho quicklift vs 2 1/2 level kit
Old Feb 27, 2009 | 05:42 PM
LIFTED07's Avatar
anyone know it the rancho quicklifts give you a the 2 1/2 of lift i have a 2 1/2 leveling kit i want to upgrade my shocks but i have 325/50/20's so i need to maintain the 2 1/2 of lift the bilsteins wont cut it from what i read you loose about a 1/2in thats why i was looking at the quicklifts.
Old Feb 27, 2009 | 06:07 PM
Windsor's Avatar
I just got a little over 2" with mine after it settled, but that was all I was after. It's possible the FX4 has heavier springs. It's hard to say what you will get out of them.
Old Feb 28, 2009 | 09:10 AM
LIFTED07's Avatar
i think they all have the same springs i could loose a little but not a 1/2in i have seen different answers on these i emailes rancho but have not got a reply from them on this.
Old Feb 28, 2009 | 09:58 AM
Windsor's Avatar
Here's the answer I got from them when I inquired:
"Thank you for your interest in Rancho products. For the 4 WD F-150 the quicklift will give you about 2 inches of lift. On the 2 WD the quicklift will give you about 1.5 inches of lift."
There are a lot more variations for springs than you might think. But for a Screw with a 5.4 and 4x4, they may all be the same. There is a lot of bolt on the top of the upper spring seat. I don't know why you couldn't stack a couple of wide washers on each bolt and cheat another 1/2" out of it.
Old Feb 28, 2009 | 11:47 AM
HYPO's Avatar
Why don't you just change out the shocks and leave the present leveling kit in? No need to do anything more.
HYPO
Old Feb 28, 2009 | 12:45 PM
LIFTED07's Avatar
looks like thats what i will be doing wanted a nicer setup without the spacer but it will have to work dont know why rancho claims there is up to 2 1/2
Old Feb 28, 2009 | 01:44 PM
Windsor's Avatar
I did have 2.5" when I took it off the jackstands. But after a week, it settled a little.
Old Feb 28, 2009 | 01:50 PM
°°Pat°°'s Avatar
Because they don't refer to F150 only. It's from x'' to 2.5'' on all the truck.
So maybe Crevrolet Silverado get 2.5'' of lift and F150 only get 2''.
Edit: 1.00" to 2.50 lift height. Depending on the vehicle and what Rancho Engineers determine is a safe height to level the vehicle out at. The exact leveling is predetermined by Rancho.
Old Feb 28, 2009 | 01:57 PM
LIFTED07's Avatar
yea i only got an butt hair from the tire to the flare at full lock with these tires. hate to trim much more and it just fits in the garage so i dont want to lift it more what size tires you running
Old Feb 28, 2009 | 04:55 PM
PHS79's Avatar
I would just up grade your shocks, Bilstein Rancho Pro Comp ect and leave the 2.5" kit in you truck. That way you don't have anything to worry about. Thats what I am going to do.
