Bedshake...How much is too much?
Old Feb 6, 2009 | 10:49 AM
sivarter's Avatar
Originally Posted by RoushF150
If it's just the left side it's most likely a tire with a flat spot. This will cause vibration on that side only. I had this problem with the original POS Badyear tires. The right side of the bed would flop around.
i have swapped tires and shocks on the back, nothing changed. do you think it would be the front that is shaking?
Old Feb 6, 2009 | 11:43 AM
c1t1d1's Avatar
Are saying its shaking that bad when you are driving on flat surface or over bumps?
Old Feb 7, 2009 | 11:53 AM
sivarter's Avatar
flat surface, everytime i get around 53-58mph it will bounce.
Old Feb 7, 2009 | 12:41 PM
RoushF150's Avatar
Most likely not. There can be a couple of other things causing the bed to shake:
  1. Out of round rear rotors.
  2. A bent or out of balance rear rim.
  3. A non-concentric wheel hub (wheel doesn't mount level onto the rotor)
  4. Bent rear axle (left or right)
All of this can cause shake. What can also cause shake are oversized wheels. Anything larger than stock or larger than stock rims (21"+) can cause shake. Balancing can be a challenge. Road force balancing can really help.
Old Feb 7, 2009 | 01:19 PM
sivarter's Avatar
i have swapped wheels and it did not change. truck is an 06 v6 with 55k miles , brakes looked good when i was swapping wheels, didnt really spin them to see if they were ob longed....but it just does it at like 55mph, no other time. it has 265/70r17's tires.
Old Feb 7, 2009 | 08:08 PM
camlocker's Avatar
When I bought my '01 Super Duty, the bed shook until I put a toolbox on it. My '04 F150, the bed shook until I put a toolbox on it. On my '06 F150, the bed shook until I put a toolbox on it. So, put a toolbox on it and it won't shake too bad.
Old Feb 8, 2009 | 12:37 AM
hmfic's Avatar
There is actually a difference in the years. I know the '07s have a support right behind the rear tires that wasn't there on the earlier years. I had a '05 Screw that didn't have the bed supports, but my '07 has them. The bounce is almost barely noticeable compared to my '05.
Old Feb 8, 2009 | 11:11 AM
c1t1d1's Avatar
How many bolts are holding down your bed?
Old Feb 9, 2009 | 12:35 AM
RoushF150's Avatar
Have a mechanic check the runout on the hubs. That will indicate a problem with an axel.
Are you the original owner? Have you hit any curbs at high speed? Has the bed been overloaded?
Old Feb 9, 2009 | 07:22 AM
sivarter's Avatar
i have 6 bolts.
and i have not hit any curbs or overloaded the bed
