power slider rattels
Old Jan 28, 2009 | 10:10 PM
sirius06sc's Avatar
does anybody eles have this problem it is driveing me nuts could it be caused by my tool box ?
Old Jan 28, 2009 | 10:21 PM
jalichoacan's Avatar
what exactly rattles??
Old Jan 28, 2009 | 10:41 PM
sirius06sc's Avatar
seems like it is the glass creeking in the seal on the fixed panels the center is queit thought maybe the center was causing it but even with the center open it still does it could it be the air getting pushed back against the glass due to the tool box
Old Jan 28, 2009 | 10:43 PM
seems like it is the glass creeking in the seal on the fixed panels the center is queit thought maybe the center was causing it but even with the center open it still does it could it be the air getting pushed back against the glass do to the tool box
oh i thaught it was something in the tailgate.. someone should be able to help.
Old Jan 28, 2009 | 11:16 PM
BayouSupercrew's Avatar
Mine doesn't rattle, fwiw, knock on wood.
Old Jan 28, 2009 | 11:51 PM
sbchris's Avatar
Let me know if you figure anything out..... mine is BADDDDDD!!!
Goes away when I wash the truck and leads to believe it is the window seal. The sliding window doesn't change anything if I play with it.
I've done a few searches and they are coming back with people having to have the whole window replaced! ugh!!!
Old Jan 29, 2009 | 12:36 PM
mkosu04's Avatar
I had mine replaced a few years ago (its a 2004) to fix this issue. It comes back... but if I bump the switch open/close it usually solves it for a week or two. I haven't gotten motivated enough to crawl back there and try to find out what will fix it.
Old Jan 29, 2009 | 12:44 PM
cstanek's Avatar
I have a rattling that I thought was the window, but when I hold up on the headliner right behind the sunroof, the rattling stops. Are you sure it's the window?
Old Jan 29, 2009 | 09:48 PM
sirius06sc's Avatar
yes i am sure it is the window no other noises from the interior i think i will explore this tomorrow i will start by removing the toolbox and seeing where this leads me
Old Jan 30, 2009 | 12:02 AM
Shanks12's Avatar
yeah i have the same squeaking.... but soon as i crack open the window it goes away.... no idea what it is
Old Jan 30, 2009 | 12:13 AM
ian51279's Avatar
Mine does it a little, but not very often. If I open and close the slider it goes away.
