Truck Stumbling From Stop
Old Jan 27, 2009 | 10:40 AM
Smokewagun's Avatar
So, I got tired of the stock program several weeks ago, and went back to my Troyer Tune - 93 Octane Performance with 3.5" AF-1 Intake. Since then, the truck slightly stumbles every time Itake off from a stop when you initially get on the accelerator. It doesn't die, but stumbles a bit. It never did it stock, and never did it before with any program - VMP or Troyer.
What could it be? I thought that maybe I could try cleaning off the MAF sensor as I just cleaned my filer and reoiled it, but the sensor looks fine. No codes are being thrown, but it's annoying me. Otherwise, she runs fine down the highway.
On Edit:
I see the AIC could be a culprit, but I read that a 2008 does not have an AIC. Is this true? Is it controlled by electronics? I wonder if this issue is realted to the high-pitched whistle coming from the trottle body "area". Maybe a problem trying to surface.
Old Jan 27, 2009 | 03:56 PM
Turd Furguson's Avatar
I would try defaulting it back to stock. Then reload the tunes you want.
Old Jan 27, 2009 | 04:37 PM
05RedFX4's Avatar
Hey Smoke, mine did the same thing, turns out it was the 90 degree rubber boot between the AF 1 and the throttle body was slipping off the TB. Just put it back on and tighten the s**t out of the clamp.
Old Jan 27, 2009 | 07:39 PM
Cypress700's Avatar
Mines done it since the Troyer stage 1-Same setup I just went with the MBRP duals.Tried to call today but the machine that answered couldnt offer any solutions.I just need to supercharge and be done with it!
