Body lift or cranked coilovers?
Old Jan 19, 2009 | 01:36 AM
Indo's Avatar
Alright so this is my truck now..
http://i23.photobucket.com/albums/b3...io/03_30_2.jpg
I want to run 37s and would like to know your guy's input. Should I go with a 3" body lift or crank some coilovers with an AAL for the rear?
Here's a banana for all those who participate..
And here's some beer for all those who aren't into bananas..
And cigarettes too maybe?..
Thanks.
Old Jan 19, 2009 | 01:43 AM
mSaLL150's Avatar
I personally think your truck looks great the way it is, I wouldn't change it.
But if you are set on it, do the body lift. Dont sacrifice the suspension w/ bad angles.
Old Jan 19, 2009 | 02:26 AM
06yz250f's Avatar
if you do a body lift to get 9" of lift i would say get 38s. don't forget 37+ size tires need a regear to save the tranny. 38's would look sick on your truck
Old Jan 19, 2009 | 08:43 AM
JesseRohr's Avatar
Those coil spacers got to go anyways...why not get the Coilovers
Old Jan 19, 2009 | 09:28 AM
wandell's Avatar
I'd do the body lift and some wide 37's.
Old Jan 19, 2009 | 01:15 PM
Indo's Avatar
Thanks SaLL
I thought about doing 38s with a BL but I couldn't find any 38" toyos that were made to fit with 22s, I don't think they make them?
And to Rohr, I know them spacers aren't too pretty and I do plan on changing them out. If I did them now and cranked, I was a little worried about rubbing and my would be angles.
Old Jan 19, 2009 | 01:16 PM
Indo's Avatar
37x13.5r22 wide enough?
Old Jan 19, 2009 | 01:27 PM
06yz250f's Avatar
14.50's or 15.50's would look sick if you can find them. ill look for some. are you set on toyo's? but you would need the BL to fit them i think. if you do cranked coilovers 37/13.50's would be the max i would go if it was me. the body lift should give you some clearence to clear a wider tire with less rubbing.
you have 22's? im assuming your not using the wheels you have now
Old Jan 19, 2009 | 05:22 PM
Indo's Avatar
I'm pretty set on toyos because I like the ones I have now, just would like to go bigger. I hear mixed reviews on Kumhos which would most likely be my only other option. I don't have 22s just yet. I'm going to lift first, then try to find a buyer for the wheels and tires, adding that to the money I already have and get them 22s wrapped in 37s.
