4x4
4x4
quick question, i put the truck on neutral and put the switch on 4L, and when i put it on drive it engages, but the truck moves and it makes a weird noise, like something clicking, but loud. when i do the same but on 4H it doesnt make that same noise. is this normal or is something wrong withe my 4WD system?
tia
tia
so to go from 2H to 4H i dont have to put it in neutral right? then once its on 4H put it on neutral and then switch to 4L?
True, it is all in the manual. Under 45 or 55 I think you can switch to 4H if on the proper pavement and without spinning the tires faster than you are currently moving. To go to 4L you need to have you tranny in Neutral and foot pressed on the brake. You will definitely feel it when it engages 4L.
