sorry guys pulling the 5.4 3v out
Old Jul 30, 2008 | 07:43 PM
assasinator's Avatar
gas mileage has caused me to buy forgings for a 4.6 3v TEKSID with a turbo.
i start building the 4.6 this weekend. 8.59:1 cr and a 70mm turbo. i-beam,mahle pistons. and my tuning with a crapload of boost.
had fun. found a lot of n/a power and torque, but it has to go. no final dyno number for the last tuned version. too bad. i made 277rwhp/340rwtq untuned with little outside mods. i would guess its in the 285-300 rwhp/360rwtq range right now.
ttl guys its been fun.
Old Jul 30, 2008 | 07:47 PM
Ballin STX's Avatar
gas prices are going down man. do you think the money your spending on the new engine will compensate for the gas you have/are going to spend??
Old Jul 30, 2008 | 08:43 PM
Clifford4x4's Avatar
dumb. Sorry for my .02
Old Jul 30, 2008 | 09:24 PM
JasonFX4's Avatar
I dont see how a souped up 4.6 will get better mileage than a mildly tuned 5.4? And the money you spent doing that, will it pay for itself soon?
Old Jul 30, 2008 | 09:37 PM
Nice...
Old Jul 30, 2008 | 11:01 PM
i get 30mpg with the 5.4 tuned as lean as a 3v will allow(18:1 pt) and the timing is globally advanced 5 degrees, but i can't have daily fun. i can get the same mileage and tune it for fun with a 4.6 3v. the reason for turbo and 0-17psi dial -a -boost is still mileage. at 0-4 psi a turbo uses no more gas than N/A. but at 17psi on race gas it makes more power than anything. i just cant afford the performance i want with 5.4 3v. i could have just put forgings in this and turboed it, but bad gas mileage is useless to me. 160 miles per day. if i tune it for powertorque i get 14mpg and have to use premium.
with 8.5:1 CR and very low to no boost i can tune it (4.6 3v)for regular and still have some fun. the rods/pistons i bought are good to 800hp and 8000 rpm.
had to make a clean break. i will probably never boost it over 10psi. but at least i can. and i may keep the 5.4 and forge it in case i change my mind back. the 4v 'b' heads i have would work good on it. with a me-made intake.
Old Jul 30, 2008 | 11:05 PM
if i conservatively tune the 4.6 i assure you i can exceed 35mpg. there's more done to the car for mileage than just a tune. gears,thin tall tires,58mph,etc. the 4.6 the car came with got 28mpg totally stock. with 3.08's.
Old Jul 30, 2008 | 11:10 PM
midnight08's Avatar
and probably 1000lbs lighter than the truck.
Old Jul 30, 2008 | 11:12 PM
ThumperMX113's Avatar
The 4.6 will blow that 5.4 out of the water, good choice ...
azmidget91's Avatar
i assume you and probably many others dont know he has a mustang with the 5.4 3v
sad to see it go, did you ever get an intake built that you liked?
Old Jul 30, 2008 | 11:21 PM
midnight08's Avatar
you assumed correct. my mistake.
Old Jul 30, 2008 | 11:22 PM
azmidget91's Avatar
its cool dont go slitting your wrist over it
Old Jul 30, 2008 | 11:25 PM
midnight08's Avatar
i was actually thinking of jumping off my balcony......
Old Jul 30, 2008 | 11:27 PM
azmidget91's Avatar
might want to check out this site for some clever ideas
http://www.a1b2c3.com/suilodge/metfun1.htm
Old Jul 30, 2008 | 11:31 PM
midnight08's Avatar
all i can say is... wow.
