wanting to install 3.73's
Old Jul 22, 2008 | 06:53 PM
shocker11's Avatar
hey guys I was wondering wjeres the best place to finr a set od 3.73's for the rear I found a guy on here willing to sell me his out of his fx4 what yall think? and does anyone have a write up on a gear installation
Old Jul 22, 2008 | 06:57 PM
mSaLL150's Avatar
If you are going to go through the hassle of a gear swap, definitly do 4.10s.
Old Jul 22, 2008 | 07:02 PM
TonkaTruck33's Avatar
x2..
unless u have large tires go with 4.56 or 4.88's
Old Jul 22, 2008 | 07:05 PM
shocker11's Avatar
im only running 275/65/18's and everytime i drive our work trucks it's night and day compared to mine same truck just diff gears
Old Jul 22, 2008 | 07:26 PM
then go with 4.10's u wont regret it.
Old Jul 22, 2008 | 07:54 PM
azmidget91's Avatar
do 4.10's because with your little lift your doing im sure you willl some day want a little bigger tire
Old Jul 22, 2008 | 08:19 PM
shocker11's Avatar
what will the difference be highway wise
Old Jul 22, 2008 | 08:31 PM
shocker11's Avatar
I was just wondering on a write up I can get these gears used out of a fx4 for 50 bucks
Old Jul 22, 2008 | 08:51 PM
Tylus's Avatar
don't do it. the 3.73 change is not worth the effort/money you'll spend to change out gears. get 4.10 or 4.30 gears. It'll make your truck a different beast
about 200-300 rpm max...so you should still be under 2000 rpm at 65 mph
Old Jul 22, 2008 | 09:17 PM
shocker11's Avatar
thanks for the help guys! you mean 200-300 rpm max more? sorry long day lil slow
where can i look upwhat all is excatly in my rear end? or where can i reference my diffs id tag?
Old Jul 22, 2008 | 11:16 PM
Tylus's Avatar
I'm about 1600-1700 rpm at 65 mph with my 3.73 gears
I'm thinking you will be 1900-2000 rpm with 4.10 gears
Old Jul 23, 2008 | 12:06 AM
Bartak1's Avatar
If you have never really played with rear ends, or unless you have a buddy or two that is a mechanic (who knows what he is doing) that can help you, dont do the install youself.
Its not so much installing them, but setting them up.
Old Jul 23, 2008 | 01:12 AM
IDNC76's Avatar
X2!
Old Jul 23, 2008 | 08:57 AM
Hitched_Gibson's Avatar
Does the 200-300rpm take much from the mpg?
Old Jul 23, 2008 | 09:23 AM
05_sprcrw's Avatar
Here are two links the first one I explain what is on the id tag. And the second one is a write up on the gears themselves.
Id tag
Gear Write
up
Hope this helps.
