more performance
Old Jul 1, 2008 | 02:39 AM
Tylus's Avatar
I sent them an e-mail asking exactly what that $2700 gets you...I can't tell if it's just the upper plenum and s/c, or it's the entire kit
Old Jul 1, 2008 | 10:22 AM
openclasspro#11's Avatar
Originally Posted by Tylus
actually you do have to bump idle speed up
the idle speed is not sufficient when you re-route the new belt and UDP's. the alternator is spinning too slowly and therefore is below minimum speed to generate power
all PCM does is tell Alt to charge or not charge
incorrect-80 k + miles on my asp udp's-no overheating,no loss in power steering,never raised idle and zero issues in charging
Old Jul 1, 2008 | 01:00 PM
i.ride.suzuki's Avatar
what does that chart you posted mean? can't make heads/tails of it
At the temperature on the left, the corresponding V will be commanded. (left to right)
Old Jul 1, 2008 | 06:31 PM
RoushF150's Avatar
Based on the listing, I would assume it's the whole kit (as they mentioned it retails at $5,100+).
That's without a warranty though.
