Removing Center Dash Tray
how do i remove the tray on top of the dash? does it just pull out or what. i dont want to break it by just yanking on it
you need to take the front part of the dash off first(part that surrounds your radio/cd player)...once that is off you will see how to take the top tray out.
ok well then how do i get the front piece off
you need to get a pocket knife of flathead screwdriver and carefully pry the piece of plastic away. its hard at first then it pops right off
Ive tried so many times but im so damn scared of snapping it. :coffee:
you cant be nice about it, its going to take a little force
the easier way is to get one clip loose, the one on the top right works for me. then from the top start pulling and it pops out |
open the ash tray, and pull up from the bottom of your dash bezel. This is the easiest method.
Originally Posted by Josiah
(Post 3193727)
does anyone know how to remove the passenger airbag cover, the plastic cover around the steering wheel and the two little defroster vents for the windshield. ones on the drivers side in front of the steeering wheel and the other is in front of the passenger airbag
nobody
There is a bolt under the steering wheel (something weird like 5.5mm). Then pull down.
Originally Posted by CANNONFX4
(Post 3195398)
passenger side airbag cover im guessing your talking about the piece right above the glove compartment, in that case there are 2 screws mid way up on each side on the back its a b**** but after you get the screws out it just pops off, i left the screws out so that i can easily pop it off as for the defroster i havent pulled those off yet |
the airbag cover is the one on top of the dash with airbag wrtitten on it. i already have the front piece off
