Spring Mods (5150's, MagHytec, Exhaust)
Old Apr 7, 2008 | 03:59 PM
TonkaTruck33's Avatar
im sry.. i cant get over how nice ur truck looks. it looks clean.
Copenhagen848's Avatar
Originally Posted by VTHokieF150
What's the part number on the Bilstein 5150's you got?
Right here:
http://www.shockwarehouse.com/site/product.cfm?id=15138
Old Apr 7, 2008 | 04:02 PM
Originally Posted by Devin4X4
veryy nice truck!
how the heck is the under carriage and wheel wells so clean when you live in mich? lol
Thanks guys.
I just put a fresh coat of Zaino polish on it - great product and simple to use. As far as the undercarriage, I took the blocks off and painted them with Rustoleum along with the rear axle. I also sprayed the drive shaft with "Rust Tough"
Old Apr 9, 2008 | 04:04 PM
The only complaint/warning I have with the 5150's is that I have the exact same problem that FX4life had in this thread:
https://www.f150online.com/forums/sh...d.php?t=317812
The shock eyelet mounting sleeves that came with them are a little too big for the F150 shock mounting bolts so they clunk when going over bumps, etc, because they are loose. FX4life showed me a link to order the correct sleeves to fit however....just
They are back ordered right now though, so I won't have them for a few weeks
Thanks again FX4life
Old Apr 9, 2008 | 04:48 PM
FX4life's Avatar
The shock eyelet mounting sleeves that came with them are a little too big for the F150 shock mounting bolts so they clunk when going over bumps, etc, because they are loose. FX4life showed me a link to order the correct sleeves to fit however....just fyi They are back ordered right now though, so I won't have them for a few weeks
No problem!! I know just how damn irritating it is.... btw, truck is looking good cope! I would ask you about painting the driveshaft but I took mine in today for just that and the shop informed me I have to have all new ones made....
Old Apr 9, 2008 | 06:42 PM
Originally Posted by FX4life
....the shop informed me I have to have all new ones made....
You need to have a new drive shaft made for the paint, or because of your lift?
Old Apr 9, 2008 | 08:51 PM
FX4life's Avatar
bc of the lift...now that its lifted everything is wearing out...
Old Apr 10, 2008 | 04:49 PM
LaVaDog's Avatar
I am about to pull the trigger...on some 5150's for the rear of my FX4. I just want to make sure I have everything straight before I place my order. I am going to order 2 Bilstein (BF5-A187-H1's).....since Cope has a 4 inch lift....and I have a 3 inch block in the rear of mine, I would think that's the right shocks for me as well. But I also want to make sure I rectify this eyelet sleeve issue as well. The shocks have a 14mm eyelet and I am wanting a 12mm, so I am going to order 4 BSN-420924 / 12mm METAL sleeves. Does the rubber bushings need to be replaced too? -Thanks in advance!
Old Apr 10, 2008 | 04:57 PM
I almost positive that they don't....but I'm sure FX4life will chime in and confirm.
Those shocks should work fine - I have plenty of travel left each way.
