what shocks do you prefer?
#31
You need a floor jack and two jack stands. Their can't be any weight on the suspension while you are doing shocks. The whole truck doesn't need to be up in the air, but each end (front/rear) needs to be up in the air when you do shocks on it. Put one end on jack stands, remove the old shock (do them one at a time), then you use the jack to lift the control arm or rear axle into place with the new shocks.
#32
#33
I did not lift the truck up in the air, but I can see how that would have helped.
#34
I was strong enough to compress the driver side with my right arm and put the pin in, but could not compress it with my left arm and get the pin into place, so I would agree with Aaairman on this one. My right arm pushes a mouse around all day, so it is stronger than my left arm. I had my girlie wife crawl under and put the pin in place while I compressed the shock with both hands.
