Finally some new shoes and socks!
Finally got some new rims and tires! It took me forever to decide which offset to get.....thanks to all that helped. I didnt think they would stick out as far as they do.....can anybody tell me where to measure the offset at so i can be sure i got the rims i asked for? I ordered the +30mm offset but couldnt find anything on the rim that said they were.
armt-dawg,
First off, Nice choice those look friggin sweet.....
Now as for the offset issue, let me see if I can explain it without sounding stupid. Measure the width of the rim, lets say that those are 10" wide. then your centerline will be 5". Now + (positive) offset indicates that the mounting surface of the wheel is closer to the front of the wheel than the back. +30mm offset should tuck your wheels in to the fenders. Now like Big Smokey said it looks like you have -30 offset as (-) negative offset is how they make most deep dish wheels and it gives the vehicle a wider track.
does that make sense???
Originally Posted by Voodoochild
armt-dawg,
How side are those wheels? do you know what the backspacing the wheels were supposed to be. I can tell you how to measure the backspacing. just put a straight edge across the back edge rim and measure to the mounting surface. that will be your backspacing. it is much easier to understand and measure than offset. if the center of the rim is closer to the front of the rim then it is definatly positive offset if you can tell how much that will tell you weather it is +12 or +30. 1 inch is 24 mm. so if it is more than one inch you got the right rims. if they are + 30 offset they probably stick out because they are 10 inches wide or more.
Originally Posted by NORDFORD
Did you sell the intake in the classifieds. I never got a reply from you.
they are +30mm if my measuring is correct......guess i was being skeptical because i thought they would look different than they do......plus all the posts i read said no trimming would be needed for these specs......i had to do some minor trimming to the fenders......the rim is 18x9......lost some horse power with them big ol tires, i think e fans will be next
mine are 18X9 with +18 offset and mine do not seem to stick out as much as yours. with +30 offset yours should not have been about 1/2 an inch further in then mine. Of coarse you do have a little wider of a tire. I think if I did not have the fender flares it would be only about 1 1/2" past the fender. are yours more than that. although my rims did stick out further than I thought they would after I got them on. I think it has just as much to do with the bigger tires.
