brake pads suggestions: ceramic or semi-metallic?
Originally Posted by FX4life
i just put on carquest semi's about 2 weeks ago, so far still quiet but dust is still there a bit probably from break in and the recent snow..so far so good though.
Akebono Pro act ceramics are pretty decent. You will spend more on the pad but ceramic pads actually wear the rotor less. I have ebc rotors and would not buy them again them since one of mine was out of round right out of the box before they were put on the truck. I had to take about 5 thousands off and now they seem to be fine and I have abused them. I would look for a higher quality rotor such as brembo. The akebonos are virtually dustless and very quiet. I am very pleased with the akebonos and thier customer service is excellent. Dont buy rotors from car quest, napa, autozone ect. Many of thier brands are low quality. I spoke with someone at brembo and they should have ones out for our trucks now ( drilled). Good luck
A Pad I have not seen suggested on here before..
MOTORCRAFT Part # BRSD1083, SuperDuty Pad; Semi-Metallic, FRONT pads. I paid $81.64 to my door from RockAuto. I love them. I had 2 different types of pads from O'Rielly and hated both, I had the unlimited warrantly and the 1 year and both sucked IMO.. I'm not concerned about dust, I dont' wash my truck THAT often and its trying to stop 5500+ runaway pounds for God sake, what do you expect..
From my experiance through turning two sets of warped rotors that were turned twice each, after going to ceramic pads (correction- EXPENSIVE ceramic pads) and another set of rotors turned once, I finally woke up. I thought my original FORD pads did not give me one problem. THEN I put another set of rotors (after market) and Orileys premium semi-metalic pads and all my problems stopped. Down with ceramic!!!!! Hope this helps.
Happy motoring!!!!
Glad I came across this thread since I'm going to have to replace my brakes this summer. So, It seems like the Carquest Semi Metallic blues is a good choice. I guess that's what I'm going with. Thanks.
are my rear rotors still good?
check out the pics. Ford said i need to replace them since they're too thin to be turned. can i still squeeze out some miles out of them?
http://i64.photobucket.com/albums/h1...s/P1050228.jpg
http://i64.photobucket.com/albums/h1...s/P1050226.jpg
http://i64.photobucket.com/albums/h1...s/P1050225.jpg
http://i64.photobucket.com/albums/h1...s/P1050224.jpg
http://i64.photobucket.com/albums/h1...s/P1050223.jpg
http://i64.photobucket.com/albums/h1...s/P1050220.jpg
http://i64.photobucket.com/albums/h1...s/P1050219.jpg
http://i64.photobucket.com/albums/h1...s/P1050218.jpg
Looking at the pictures, the rotor seems to be fine enough to slap a new set of pads on. But I never use a tape measure, I use a micrometer to measure. Some of the pics are useless. But the ones that show the rotor clearly, looks like you could just replace the pads and be fine. It doesn't seem to be gouged and the serface seems to be even. If it were mine, I would consider just replaceing the pads. If stock rotors, I would not install ceramic pads. jmo
Happy motoring!!!!
